Very Confused
Old Jun 19, 2008 | 12:31 PM
  #41
PWRMKR's Avatar
[QUOTE=K7S2KGSXR750,Jun 18 2008, 07:29 PM] well i dont think it was the dealerships fault at all
I actually had driveshaft spacers there and the bolts were missing were the spacers were put in.
Old Jun 19, 2008 | 05:41 PM
  #42
Siepel's Avatar
Originally Posted by S2KenC,Jun 19 2008, 12:52 PM
Wasn't the dealership fault that the OP decided to put on a non OEM part and forgot to tighten down the bolts.
$270 does sound like a lot but then again the dealership needs to be compensated to fix a problem that wasn't covered under warranty.
I thought the OP meant the mechanic at the dealership, but maybe I need how to read between the lines...
In any case, the 'mechanic' needs to foot the bill
S.
Old Jun 19, 2008 | 05:53 PM
  #43
teanza's Avatar
S.
~tina~
Old Jun 19, 2008 | 07:15 PM
  #44
K7S2KGSXR750's Avatar
S.
Well its kind of like what i said earlier
My mechanic is very very reputable and he's helped many people on this site. And he probably just had a bad day.
So i'm not tripping that bad. Things happen sometimes and if it happened to me, i guess that just means i did something wrong and karma is getting me back this time
O well
Old Jun 19, 2008 | 08:52 PM
  #45
LOL8K's Avatar
Originally Posted by 9kFever,Jun 16 2008, 11:09 PM
80 miles is a lot. Call Norman Taylor. www.normantaylor.com
They can send the dealer a letter for about 300$ if worse comes to worse.
80 miles isn't that much for a new car, especially if it was a trade from another dealership. The average for the cars I sell is usually about 150-200. But it's possible that the guy who drove it there had no idea how to drive a stick.
Old Jun 19, 2008 | 11:07 PM
  #46
Stealth_SUX_'s Avatar
So there were bolts missing the driveshaft wasn't connected to the diff...
hmm and when they looked at ur car and said it was ur clutch they couldn't see a disconnected driveshaft...
And they actually pulled ur tranny to and then found that out.
Well if this is the case I would nvr take it back to that dealer after this.
Old Jun 20, 2008 | 06:12 AM
  #47
si2die4's Avatar
This still sounds fishy! I mean... All 6 bolts came out of the half shaft? BOTH HALF SHAFTS? I dunno about all that! You do know that with that low mileage there is no wear marks created in the CV housing so spacers are not necessary?
Old Jun 20, 2008 | 06:50 AM
  #48
Elistan's Avatar
It's quite possible that the bolts came out for only one of the half-shafts - with no load at all on one of the wheels, the Torsen LSD would act like a regular open diff, and would just spin the one side.
And that should have been obvious after a quick visual inspection - for the dealership to want to pull the transmission means they didn't do any diagnostics on the issue at all.
Old Jun 20, 2008 | 11:13 AM
  #49
not both sides, just the drivers side
i put the spacers on because i lowered the car
vbb
Sep 27, 2011 08:44 PM
Mooseman
May 12, 2011 04:43 AM
stwokayyy
Jul 1, 2010 12:22 AM
Hiroprotaganist
Jun 24, 2010 01:37 PM
Fusiondynamics
Dec 17, 2004 08:01 PM
