Vibrating noise
Old Jul 23, 2007 | 12:35 PM
f20cpower3's Avatar
Default Vibrating noise
my AP1 makes a vibrating noise when decelerating from high or mid RPMS. Does anyone know what causes this or what I can do to fix it?
Old Jul 23, 2007 | 12:45 PM
speedmaster's Avatar
Is it sound like it is coming from behind the seats???
Old Jul 23, 2007 | 12:47 PM
tekstar's Avatar
Look up threads on clutch buzz. You can either get a new clutch, or live with it. It is not bad, just annoying.
Old Jul 23, 2007 | 10:25 PM
f20cpower3's Avatar
im not sure it only happens when you let off the gas between 4,000 and maybe 7,000 RPMS. It seems worse when the A/C is on.
Old Jul 23, 2007 | 11:39 PM
tekstar's Avatar
actually, i have this same problem. except mine is from 5k+
i tried posting for a response before but no one replied
i only noticed mine happening after i did my 60k maintenance so i have no idea what it is.
for some responses!
Old Jul 24, 2007 | 01:48 AM
NHOJ's Avatar
sounds like the rear glass but isnt ? and its behind u mine came from the trunk at one point (jus one of the causes cant find the other) at some point the tension rods? whatever u want to call it for the trunk one shifted a bit and start pressing against the other with the trunk closed i tap on the rear of the car the plasitc jus infront of the trunk lid and it rattles. i readjust the rods periodically but they shift again once in a while
Old Jul 24, 2007 | 03:53 AM
The plastic tray the rag top lays in will rattle and buzz sometime. Mine did after I installed a new exhaust.
Old Jul 24, 2007 | 03:00 PM
GoKart3's Avatar
Prolly the clutch buzz. It's TSB-0054. TSB link from the FAQ page.
Here's the complete FAQ page, which is your friend.
When I had the TSB performed at my Honda dealer, I explained to my service writer that I was grateful that Honda was going to perform this, but that I really didn't want the buzz back in a few months, which happens to a lot of guys. So, the performed the clutch job with some of their parts, and some of mine.
They installed the *updated* Honda disc, throw out bearing, and pilot bearing. I supplied a Comptech lightened flywheel and an ACT pressure plate. They installed all of it. No problems with the cluth since. Buzz has been gone for almost 2 years. No worries.
You probably can't get the Comptech flywheel anymore, but you can get an ACT flywheel which is a nice piece. You can get the parts here.
Hardtop Guy
Do a search for "tsb 0054" and you should find plenty of threads that will describe the problem. At about 35 mph in 3rd gear under decel, that sucker outta buzz enough to make you wanna drive the car in a focking ditch.
yitznewton
Apr 27, 2017 06:27 AM
Acethriller
Jul 14, 2015 11:25 AM
Thomp
May 16, 2005 01:49 PM
no1fa
Aug 8, 2001 03:04 PM
airgate
Dec 3, 2000 08:08 PM
