Voodoo shlobbed my knob
Originally Posted by Slows2k,Apr 26 2006, 06:04 PM
Put a tap in a vise, and thread the knob on to the tap. (8x1.25 I believe) Turn the knob untill the shift pattern lines up, you'll be cutting just a small section of threads.
I think I might just use that 2 drops of loctite you guys recommended
Should I apply it to the inside of the knob itself--or the shifter threads itself??
Thanks Boooyz
-Paul
Thanks for the correction on the threads, I was going by memory. The threads on my old engraved knob where not cut to the bottom of the drilled hole. Adding about 90deg of threads made the pattern line up perfect.
Originally Posted by TryPsi41,Apr 26 2006, 10:29 PM
I dont really know what a tap is.....Hmm..
Thanks Boooyz
-Paul
Thanks Boooyz
-Paul
not to hijack the thread but i am fed up with antenna thefts, if i douse it with red locktite will that mean i will never be able to take off the antenna again? or will it just be harder?
also, is there ever a reason to take of the antenna? only reason i was doing it was to prevent theft..
Originally Posted by Slows2k,Apr 26 2006, 08:31 PM
A Tap is used to cut threads. http://en.wikipedia.org/wiki/Taps_and_dies
at title.
