VSA, (!), check engine light, sputtering problem
Old Dec 17, 2010 | 12:46 PM
daicacharco's Avatar
Default VSA, (!), check engine light, sputtering problem
Seeking for some advice and help on a problem I have recently been having. I just recently boosted my08 with the SOS stage 2 kit. Randomly when I am cruising on the freeway or city driving my car randomly starts sputtering. My vsa, (!) symbol, and check engine light starts flashing when it occurs. When it occurs the car sounds like a sti wrx. Sometimes the vsa and (!) symbol lights will pop up and stay on. It goes away after turning off the car and turning it back on. Not sure why it happens. It used to be fine. Started happening after a few weeks replacing the driverside axle when I had snapped it. Any inputs or suggestions will help.
Edit* if i put my car on neutral and rev it out the car will stop sputtering and go away but the vsa and (!) sign will stay on.
Old Dec 17, 2010 | 01:11 PM
CapoArgentino's Avatar
Banned
No CEL coming on? If yes then pull the codes. If not, I would contact the person who installed the SC and/or SOS themselves about this issue. Maybe they encountered the issue during development or might have an idea why.
Old Dec 17, 2010 | 01:29 PM
I will use a obd2 scanner as soon as I get a day off. There is a cell on right now and it's the primary 02 sensor failure. I have a new one but am waiting for a day off to install it. I will update asap. The car has been boosted for about 3-4 months and this occurred about 2-3 weeks ago.
Old Dec 17, 2010 | 04:03 PM
flyingtoaster's Avatar
The VSA and (!) light will come on for reasons that have nothing to do with the VSA system. I recommend parking the car.
Old Dec 17, 2010 | 07:12 PM
Car is parked and has been.
Old Dec 18, 2010 | 08:02 AM
topdwnsomyheadfits's Avatar
im thinking a misfire. either a coilpack or sparkplug failure. My 07 Si had the same problem before and it ended up being a coilpack failure. VSA ! and CEL were all on.
Old Dec 18, 2010 | 10:19 PM
davidc1's Avatar
I've read that a "flashing" CEL light is bad news. That you should stop the car immediatley.
Old Dec 19, 2010 | 09:26 AM
Checked my plugs, one of the coil plug seals are torn.
darkalley
Mar 12, 2012 09:03 AM
rayman1031
Apr 26, 2009 06:21 AM
tadao916
Mar 2, 2009 04:47 PM
S2k007
Jun 19, 2003 12:17 PM
turbomadness
Feb 18, 2002 11:05 AM
