When to replace brake lines
Old Mar 20, 2013 | 06:18 PM
2003AP1's Avatar
Change the fluid.
As long as the lines are not leaking I would say leave them alone.
Old Mar 20, 2013 | 07:10 PM
starchland's Avatar
Interesting answers guys. I change my fluid once a year with dot 4. Lines look fine. My old car was a 1992 and I never worried about the lines on the track
Old Mar 21, 2013 | 05:41 PM
Pinky's Avatar
I have an '00 ran winters for a few years. Last winter swapped out for SS lines. I cut in 1/2 one line just to see what it looked like inside and how it was holding up after all these years. LOOKED AWESOME. It's an outer rubber then a braided middle and inner rubber. If you aren't seeing any cracking in the lines you are FINE.
Old Mar 21, 2013 | 06:05 PM
starchland's Avatar
Thank you gents. Will inspect the lines again when I flush.
Old Mar 26, 2013 | 02:50 AM
daktruckie99's Avatar
It's not always the quality of the line though, it's the heat fatigue of the crimp joint. See here for another OEM brake line failure:
https://www.s2ki.com/s2000/topic/1012717-a-close-call/
Old Mar 26, 2013 | 03:20 AM
redlineracing's Avatar
Like everything else..."When in doubt...change it out"
\rlr
Carolina
Old Mar 26, 2013 | 04:47 AM
zeroptzero's Avatar
I guess age isn't the only factor, that car was an 07. It probably would have had a much lower chance on a street driven car though. New lines are relatively cheap, and an easy DIY job.
trackrabbit21
Aug 11, 2015 11:14 AM
Chablonski
Mar 17, 2010 10:22 AM
dmw16
Nov 3, 2006 05:21 PM
TunedS2000
Apr 5, 2006 05:28 AM
