Where is the engine hook?
Old Aug 25, 2012 | 04:51 PM
s2kseven's Avatar
Default Where is the engine hook?
I'm trying to install a used engine, can someone tell me where is the engine hook located?
I bought this engine used and maybe there is no hook?
Thank you
Old Aug 25, 2012 | 05:13 PM
xviper's Avatar
There are no "hooks". There are threaded holes in the block where you can screw in a bolt with a hook or ring to lift the engine out. One is near the front right of the engine, near the VTEC solenoid. The other is at the rear on the opposite side. In this picture, you can just see a bolt threaded through a black bracket and into that hole. Vortech uses this hole as an attachment point for the supercharger mounting bracket.
Old Aug 25, 2012 | 05:54 PM
zeroptzero's Avatar
The other hole is on the intake manifold, you need to get two bolts and put them through a chain and then hook the chain to an engine hoist. I believe the bolt threads need to be 10 x 1.25
Old Aug 25, 2012 | 06:05 PM
s2kseven's Avatar
Thank you people....appreciate the help
Greg Bell
Aug 15, 2016 05:01 PM
rob2.2
Feb 23, 2011 12:45 PM
Tech7427
Nov 6, 2010 05:34 PM
rudeS2k
Dec 30, 2005 07:19 AM
ideugene
Nov 6, 2005 08:00 AM
