Where Exactly is the Timing Chain Tensioner
Old Feb 12, 2010 | 06:48 AM
W00LY MAMM0TH's Avatar
Default Where Exactly is the Timing Chain Tensioner
So I just read another thread about a chain tensioner going bad a 6k miles, and his makes alot of noise at idle. Well mine does the exact same thing so I was wondering where does it exactly sit and what do I have to take off in order to get to that thing? Thanks!!!
Old Feb 12, 2010 | 07:01 AM
wisdom's Avatar
It's right beneath the vtec solenoid.
Search for pictures and it's in the sticky.
Old Feb 13, 2010 | 08:49 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Far left side of the pic is the TCT, held in by two bolts. The TCT itself also has a cap that has it's own two bolts.
You can see through the maintenence hole, and see the small pull-pin.
I've put the timing chain guide on the outside for the pic, so you can see what the TCT pushes against inside the engine.
Sideways
Sep 27, 2011 01:20 PM
macr88
Engine
Jan 28, 2010 12:25 AM
rob-2
Jul 30, 2009 01:27 PM
vabchs2k
Sep 21, 2007 04:48 AM
i</3speedbumps.
Sep 25, 2006 09:07 AM
