Hosed The Clear Coat!
All,
I'm not too happy with myself right now. I think that I hosed my ride's finish.
Last week, my Stook ran powered through a major rock meteor shower. The left fender was hit pretty hard and I had a couple of hits that scraped off the paint all the way down to the sheet metal. I thought that I could take care of it. Initially, I dabbed the Honda pen to the affected areas but was not pleased with the "bubbles" after the applications dried. I used a fine wet/dry sandpaper to level the bumps but in doing so, I believe that I hosed up the surrounding clear coat.
Is there such thing as a clear coat repair? The paint is fine, and I do believe that I didn't sand off the entire top coat... but the sanded area is dull and I can't buff it out. I'm thinking that a new application of clear coat and a buff would do the trick.
Your help will be greatly appreciated. I'm sure that there's a way to fix this.
Please send a PM if you have words of wisdom.
Thanks,
CB
Thanks,
CB
Originally Posted by petraidm,Jan 13 2005, 05:32 AM
I'm in about the same state as "thetz99". My repair area is on the top of the left fender and it is about a foot long and 4" wide. I suppose that I could buff it out with finer sandpaper, but I'm also quite aware that the clear coat is being stripped down. Couldn't I get ahold of some clear coat, spray it on and then blend that in with superfine sandpaper?
I contacted a local paint shop and they have "generic" clear coat.
AND is the Porter Cable buffer a must have?
Word?
CB
Word?
CB
Originally Posted by thetz99,Jan 13 2005, 11:14 AM
I googled up some info on clearcoat or lack of...
The base coat is dull by nature. Clearcoat is what makes the paint shine.
How do you figure I burned through my clearcoat Ubetit?
A clear coat is about 1-2mm thick and the urethane is fairly soft. Most people think a clear coat is hard like glass. Always use a block to wet sand as your fingers will apply pressure unevenly and you'll be left with ridges that will take forever to get out. Practice on a beater or a panel from the junk yard first.
Hey,
I want to thank you guys for your input. I really thought that I had hosed my stook's skin up.
Here's what I did to get out of this jam...
I acquired 1500, 2000, and 2500 grit wetordry sandpaper from my local autobody supply store.
I wet sanded lightly using the 1500 then graduated up to the 2500 - keeping it wet and extremely light pressure.
Then, I used "Ultra Cutting Creme Light" from Presta to get rid of the tiny swirls.
Finally, I put a coat of Meguiar's "Gold Class" clear coat liquid car wax.
Viola!
And, BTW, I did it all with elbow grease. I couldn't justify the buffer buckage at this time.
Dudes, I was so disturbed that I came home from work early to work on the car. Thank goodness it worked.
Thanks for all the help.
CB
Viola!
CB
