How do you clean the "ENGINE START" button?
Old Oct 18, 2003 | 12:04 PM
WhiteS2k's Avatar
Default How do you clean the "ENGINE START" button?
After almost 4 years, I noticed that my "ENGINE START" button is collecting dirt in the recessed lettering. So what is the best way to clean the dirt out of the recessed lines of the letters? Wiping does not help, as the dirt is below the level of the surface. Thanks.
Old Oct 19, 2003 | 02:23 PM
tigerfan's Avatar
Have you tried compressed air?
Old Oct 19, 2003 | 02:48 PM
boiler's Avatar
I would try an old toothbrush and a mild cleaner. Anything strong might remove the paint in those dirty letter grooves.
Old Oct 19, 2003 | 03:17 PM
VTEXTC's Avatar
Dab a "Q-tip" in some simple green and work at it. Shouldn't be a problem since the contours of the Q-tip will be able to swish out any dirt in the grooves of the letters.
Good luck
Asif
Old Oct 19, 2003 | 04:28 PM
s2ksimon's Avatar
for those small places the compressed air cans with the thin plastic nozzle works well. Then I too do the Q tip thing
Old Oct 19, 2003 | 09:39 PM
wanabe's Avatar
exactly my post from about a month ago!!
simple green applied to a towel then to the start button... also the emergency blinker button,
should do the trick.
more ideas are in my thread, if you want to search for it.
good luck!!
Old Oct 19, 2003 | 10:10 PM
forsaken's Avatar
Toothbrush is the best.. the one with soft bristles..
Old Oct 20, 2003 | 08:22 AM
WhiteS2k's Avatar
Thanks. I did a search (for "engine start clean") before I posted my question and nothing came up. Thanks for the pointer to your thread:
start button cleaning
You asked the exact same question I did. I will try some of the suggestions made. Thanks again.
06s2kid
May 10, 2016 09:35 PM
ssnead
Aug 3, 2014 04:11 PM
ryanswhites2k
Jun 8, 2009 06:56 AM
s2kdriver80
Feb 15, 2007 04:57 AM
wanabe
Oct 2, 2003 10:04 AM
