Paint problem.
Old Nov 21, 2005 | 01:48 AM
kennyr's Avatar
Default Paint problem.
fixed.
Old Nov 21, 2005 | 05:06 AM
Eluded's Avatar
dont they fix it?
Old Nov 21, 2005 | 07:31 AM
mosesbotbol's Avatar
Have them figure it out. Are you going to try to paint it yourself?
Old Nov 21, 2005 | 09:02 AM
kennyr's Avatar
Honda dealers in sweden atleast to my knowledge dont do paintjobs.
Old Nov 21, 2005 | 09:09 AM
dangarza's Avatar
If it's a minor scratch, you may want to consider just a "touch up" job, rather than the full works of painting the whole panel which, to be done right, most likely would need that strip removed.
Then, a few months from now, when reinstalling the hard top, they might screw up and scartch it again...
Old Nov 21, 2005 | 10:11 AM
C4SxM5's Avatar
That strip you are asking about is a BITCH to remove. Basically seats and all rear plastic pieces have to come out. The soft top will then need to be removed and finally the metal lining that you are asking about. I personally wouldn't remove it because they re-install won't be correct IMO, but its up to you....
Old Nov 21, 2005 | 01:49 PM
S2k Dude's Avatar
Isn't that the part that you have to drill out all the rivets in order to remove it?
Old Nov 21, 2005 | 03:24 PM
centralcoastbuc's Avatar
Yes, but you don't have to remove any rivets. You just unbolt the backing plate an pull the top back from the body (after you remove the seats, rear plastic etc. Even after that it is tough to get to the bolts nearest to the doors and get the strip out without scratching the paint. I had to do this so the shop could reclear my rear quarter panel. I didn't trust the shop to do it right.
I would suggest that you get one of those airbrush touch up guys to try to fix it before going to all of that work.
Old Nov 22, 2005 | 02:57 AM
kennyr's Avatar
thanks for the replies.
dfvs2k
Jul 28, 2010 03:38 PM
kalikart17
16
Mar 24, 2009 04:08 PM
gambit023
May 10, 2007 07:30 PM
animeS2K
May 2, 2005 10:37 PM
frankyknuckles
Mar 18, 2003 10:25 AM
