Exhaust smell from HFC?
Old 04-04-2018, 04:01 PM
klapamos's Avatar
Default Exhaust smell from HFC?
Hey all,
I have noticed about a month ago that when the windows or top is down I will sometimes notice a minimal to moderate exhaust smell. I'm thinking the smell could be from my Berk HFC that was installed about 6 months ago, thoughts? I do have a small radiator leak...not sure if that could be part of the issue. The radiator (KOYO) and hoses (OEM )are being replaced this weekend.
Old 04-04-2018, 04:35 PM
Car Analogy's Avatar
Received 1,315 Likes on 993 Posts
Coolant has a sweet odor. Difficult to mistake for exhaust smell.
You have a hfc, so thinking maybe you have an aftermarket cat back. Which means its probably a bit loud. Which means maybe you wouldn't easily hear an exhaust leak. So, maybe check for that.
A hfc that is going bad often has a rotten egg smell.
Old 07-15-2018, 06:31 PM
klapamos's Avatar
So I had my front brakes replaced including rotors, calipers, and pads, as well as the new radiator installed. The majority of the smell has stopped, but I still get an occasional slight exhaust smell for a second or two at stops. I suppose I should take it to a muffler shop...it has the berk HFC and UK mod on stock exhaust. My AP1 does go through ~1 quart every 1000 to 1200 miles.
Old 07-18-2018, 09:17 AM
Mataleao9380's Avatar
I have the Berk HFC and UK mod done on my car as well. The slight exhaust smell is normal mainly but it's mainly due to the HFC. I had the UK mod done first and it had no change from stock (smell wise).
Old 07-18-2018, 10:54 AM
Chuck S's Avatar
Received 1,133 Likes on 996 Posts
Berk high flow cat and Tanabe Medalion Touring on my car. Backed into the garage (of course). If there was gonna be any smell I'd notice it. Not a thing.
-- Chuck
Old 07-18-2018, 11:03 AM
zeroptzero's Avatar
Received 3,373 Likes on 2,452 Posts
you will get some exhaust smells in some conditions, mainly cold idle. That's the reason the HFC has a built in anti-fouler as it does not convert as well as an oem cat. Nothing to worry about though.
Old 07-18-2018, 11:06 AM
TsukubaCody's Avatar
I have a little exhaust smell from my HFC, 2500 miles on it, things could be worse.
Petron
10-08-2010 01:50 PM
jonner
06-20-2007 04:01 AM
JLEEzAP2
04-27-2006 12:32 PM
S2Kasey
06-22-2004 10:02 AM
tenblade2001
08-26-2003 06:33 PM
Quick Reply: Exhaust smell from HFC?
