Aircon Compressor Clutch
Old 10-10-2018, 10:32 PM
sohcy's Avatar
Question Aircon Compressor Clutch
Hi all - this is my first post in this forum.
I own an AP1 - I have noticed that the AC clutch doesn't spin at all even with AC turned on.
I check the wire by multi-meter and can't see any voltage going to the compressor.
For testing - I connected a direct wire from the battery and the AC clutch worked - also the aircon is blowing cold air.
I check the fuse under the hood and swap them over with the horn but still no luck.
Appreciate any advise.
Old 10-11-2018, 03:21 AM
Slowcrash_101's Avatar
There's a load protector on the compressor which also acts like a fuse, have you checked this?
Old 10-11-2018, 03:24 AM
sohcy's Avatar
Hi slowcrash - an aircon mechanic will check the car tomorrow. Since the ac worked on direct battery - I am hoping a re-gas will fix the problem
Thanks
Old 10-14-2018, 02:50 AM
sohcy's Avatar
Turns out that there is no ac gas. No leak upon testing by a professional ac mechanic. Simple re-gas fixed the problem
Old 10-15-2018, 03:49 AM
I hope you put in a little oil as well.
Old 10-15-2018, 04:32 PM
starchland's Avatar
Where was the leak?
Old 10-16-2018, 08:08 AM
summitrider2012's Avatar
Did they add die? Alot of times a leak will show after a couple weeks of running but die needs to be added.
St1tch2k
08-22-2017 03:52 PM
TakeshiS2K
09-28-2016 10:29 AM
matt0488
03-21-2015 03:02 PM
Andersonracing
02-13-2013 01:57 PM
slvrstnS2000
09-25-2007 10:32 AM
Quick Reply: Aircon Compressor Clutch
