SOS question - small water pump for aftercooler has stopped working
Old 04-24-2019, 10:42 AM
blue monster's Avatar
Default SOS question - small water pump for aftercooler has stopped working
Question for those with the SOS kit. There is a small water pump that sits behind the front bumper & is awkward to get to & is linked to the after cooler that has stopped working. I've had this happen before & it was just a bad / corroded connection but I am off to Italy from the UK next week & will be doing a lot of driving over 9 days and don't want to have any hassle. Does anyone know what type / model / make of pump it is or an aftermarket one that use to replace the SOS one?
Old 04-24-2019, 03:02 PM
Jack_in_the_Box's Avatar
I would just upgrade if you're going to replace it. I replaced my stock Johnson pump with the Bosch pump used in the SVT Cobras when I upgraded to the larger heat exchanger. It's also much more quiet.
https://www.ebay.com/itm/BOSCH-COBRA...-/271628657673
Old 04-24-2019, 06:51 PM
hecash's Avatar
I went with the same Bosch pump bought from Frozen Boost but I kept the small, original heat exchanger. I did not see much, if any, of an impact of the larger (1,200 lph) capacity with the smaller exchanger.
Old 04-24-2019, 08:09 PM
jdmz's Avatar
If you are interested in the stock small one, I've got one that I don't need anymore.
Old 04-25-2019, 11:17 AM
Jack, managed to find one of these today & got it on courier to be delivered tomorrow
Old 04-25-2019, 08:28 PM
MARK AUS S2K's Avatar
Best idea.
This is what hundreds of others have done, it's what you should have purchased before you installed it.
Old 04-27-2019, 01:43 AM
E4RTH WORM JIM's Avatar
Originally Posted by MARK AUS S2K
Best idea.
Agreed
Have a good trip!
Old 04-27-2019, 01:13 PM
Originally Posted by E4RTH WORM JIM
Agreed
Have a good trip!
Cheers James!
killerbee_vr6
05-01-2015 11:38 AM
jordannn93
12-31-2011 02:04 PM
slackfaster
06-02-2006 03:16 PM
krazik
06-30-2004 09:50 AM
Shamu
05-21-2002 05:53 AM
Quick Reply: SOS question - small water pump for aftercooler has stopped working
