Cel p0133
Cel p0133
Hey guys,
My previous setup was stock header, TP and stock exhaust running Kpro with tune by APH. I swapped the exhaust to a single back, and now I'm getting a CEL P0133 Oxygen Sensor Circuit Slow Response can anyone make sense of this?
Is the sensor 100% plugged in? I recommend going back under the car, unplugging and plugging it back in. Make sure you hear the tab click. The oxygen sensor heater circuit is a very sensitive circuit, so any disruption will throw a code.
If you do this and the light comes back, then either the sensor is bad (which may just be coincidence, but they do go bad and a TP accelerates the wear on O2 sensors) or you may have pinched some wiring in process of swapping exhausts and damaged something.
S2K4WIN (10-06-2017)
I had that once and it was as Fernando stated, the o2 sensor was not tightly clipped it at the connector on the tranny mount location, I gave it a firm closing tight and the CEL went away. If it comes back later check the connector.
