Bolt size for coolant line in block for oil cooler
Old 08-13-2013, 12:29 PM
s2konroids's Avatar
Default Bolt size for coolant line in block for oil cooler
I'm removing the factory oil cooler and need to find a bolt for the hole that will be left vacant in the block when i remove the cooler.
I mean the coolant line that goes to the block.
Does anyone know the thread/pitch/length etc?
Cheers
Old 08-13-2013, 02:04 PM
mr-pitts's Avatar
Wont you have to connect a hose from the pipe that runs across the front of the engine to complete a circuit? Thats what ive done with mine.
Old 08-13-2013, 02:08 PM
s2konroids's Avatar
I'm not quite sure mate, the turbo is water cooled I'd expect two hoses but think i only have one.
I think the oil cooler will be removed and thus replaced with a take off plate.
I could even take a water from the front of the block but just want what's the easiest.
Cheers
Old 08-13-2013, 06:46 PM
mr-pitts's Avatar
My way of thinking Aj is that you must have a feed and return to complete the coolant circuit.
Old 08-13-2013, 11:45 PM
razzele's Avatar
The water lines are just push fittings and as mr Pitts said you need a return for the water.
Otherwise it wouldnt flow .
s2konroids
11-22-2021 09:06 AM
s2kneub
11-17-2013 08:05 PM
westfield147
01-28-2012 05:02 AM
bamboosted
06-09-2011 10:55 AM
cbender
11-11-2004 08:03 AM
Quick Reply: Bolt size for coolant line in block for oil cooler
