evans coolant
Old Jun 14, 2013 | 04:44 PM
simonss2000's Avatar
Default evans coolant
Has anyone used this stuff on a long term basis in their s2000 n/a,turbo,supercharged
http://www.evanscooling.com/
Claims to prevent overheating
Old Jun 14, 2013 | 07:00 PM
razzele's Avatar
Old Jun 14, 2013 | 11:04 PM
richmc's Avatar
Try a search, it's been mentioned before when it was "advertised" on Wheeler Dealers. I know of a couple of performance cars using it with no problems, very bizarre taking the rad cap off when it's hot.
1) Doesn't prevent overheating, just won't boil and burst bits if it does.
2) Fecking expensive.
3) PITA to go from antifreeze to this stuff as all water must be removed, you have to fill it with a prep solution that absorbs water for a few days.
4) If you get a leak for any other reason, see 2.
The claim that it affects the operating temperature of the engine is bollocks, that's down to the thermostats mechanical operation alone and it's not going to change that, same goes for the fan.
Old Jun 15, 2013 | 01:48 AM
Dembo's Avatar
All coolant prevents overheating, so I suppose that claim is 100% true.
Old Jun 15, 2013 | 02:02 AM
razzele's Avatar
I think they get away with this as most people perceive over heating as the car boiling over and taking a wee.
As this stuff doesn't seemingly pressurise you have less problems with expansion related leaks. For example some cars (thankfully not ours) have those in hose rubber bleed valves. Under hard use on cars like the vx220 it's known for those valves to let go when the temp goes up.
As far as heat exchange goes I believe that water has the highest values, but it boils, expands and corrodes the internals! And after pricing up Evans (£160) I thought bugger that! Water with wetter and some antifreeze stuff for me!
Ill be testing a few different things on track in the yellow car hopefully soon!
Old Jun 15, 2013 | 02:06 AM
richmc's Avatar
Its the circulation of the coolant through the radiator (with fan etc) that prevents overheating, not the coolant. Whereas the absence of coolant will cause overheating.
Old Jun 17, 2013 | 07:26 AM
gbduo's Avatar
If it is better at absorbing and taking away heat than water as you can run it at higher pressure or whatever then the only purpose I can see is that you can run the engine leaner and hotter, so more power whilst maintaining normal op temperature.
But then you would have to have your pistons/head improved to do that so I don't see the point when water is like free...
Old Jun 17, 2013 | 08:35 AM
richmc's Avatar
The engine will run at the same temperature unless you replace the thermostat and do somthing to change the fan cut in, other than that its no better at conducting the heat, as for running at higher pressure it runs at very low pressure as in my post where I said you can take the rad cap off when its hot.
Watch the vidio then you will learn what it claims to do -
http://www.evanscoolants.co.uk/news/wheeler-dealers-–-watch-now!--edd-china’s-triumph-tr6-conversion-./43
speakeasy2009
Jul 31, 2017 10:44 PM
peiserg
Feb 5, 2016 03:15 PM
Opie Oils
Mar 2, 2011 05:45 AM
notyourfriend
Oct 22, 2009 11:31 AM
S2K_Spain
Feb 26, 2001 02:36 PM
