Exhaust Drone on after market Exhausts
#22
God know if it's been tried ,
I suppose ultimately using your logic why not 4 pipes all the way !
If 2 or 4 pipes would have an effect on drone I have no idea , as I say my understanding is it's all to do with the gas pulses generated by the exhaust gases being ejected from the engine via the exhaust and these have a frequency directly linked to engine rpm and the way that frequency reacts with other parts of the car , so stop or cancel that frequency and bingo no drone and the Hemsoltz supposedly does just that generating the same frequency but out of phase cancelling the pulses from the engine at approx 130 hz . It's the same effect as blowing across the top of a bottle , hence Honda must have had a higher frequency drone from the OEM pipe hence the 8inch resonator .
#23
UK Moderator
Maybe rip out the insides of a pair of noise cancelling headphones and plumb them into the stereo?
#24
HALOsonic noise managment
http://www.halosonic.co.uk/
or maybe another gadget idea for different Hemsoltz pressure variables.
http://www.ebay.co.uk/itm/2-5-Exhaus...item4178bfbc58
#25
Leave the manifold as is changing it will lose power. 400c is the minimal temp you want to work it on under load when drone comes it will be up to 600c. When I worked it out at 400c it said 42" so I am going to add at least 6" to my 38" pipe. It makes idle much quieter as a result too!
#26
Has any one retro fitted a Hemsoltz resonator to an after market exhuast to cancel out drone of the 130ish Hz variety ?
Found lots of information regarding this and how many OEM pipes include these but often buried in a box some where , the S has one about 200mm long, which would suggest there was a problem at a much higher frequency .
From what I can make out I would need one around 26 to 28 inches long to deal with 130hz drone , I am looking to come out of the side of the decat pipe turn 90% and calc the length on the mid line of the bend , also th ink of adjustable length ( think trombone here ) to fine tune it . Then length has to be about a 1/4 wave of the annoying frequency wave length .
In the states this appears to be a commonly used solution on quite a few vehicles , Mustangs , SRT10 Dodge and lots of after markets pipes for various cars like 350/70 Z,s
Other solutions like bungs , and additional silencers negate the point of fitting a high flow pipe in the first place , a resonator has no effect on flow or very little , it acts purely to mirror and cancel the frequency causing the problem.
#27
^^Think Chippo went back to oem
what xaust have you ?
#29
Ive done a helmholtz resonator on my old skunk2 system. eliminated about 80% of drone. But it was not a small thing. About 5L of volume from memory (Maybe more).
A good read here:
https://www.s2ki.com/forums/s2000-un.../#post24473525
A good read here:
#30
^^ Was reading that topic
