headlamp washer pump replacement
Hi guys, I need to replace the above as well as the pump for the screen washer for my MOT, I have found a few threads re the screen washer, which looks like an easy(ish) fix with a halfords part but I cant find anything on the headlamp washer. Does anyone know if this is a fairly easy replacement and whether its a generic part I can pick up? any advice much appreciated. Thanks
I've replaced both pump motors on mine; the windscreen one is a doddle and can be sourced easily as you say.
The headlight washer pump motor however was a complete bugger, it's the big jobby that sits above the small windscreen one and looks like this.
I bought mine 2nd hand from a forum member and it's still working.
To replace it was a knuckle scraping swear fest, I wanted to remove the reservoir to make the job easier but there's a screw that can't be reached without (I think) removing the wing.
So in the end I just bodged/twisted/scraped it in with brute force
Good luck OP and if you find a shortcut/decent method etc please share
Here's some mucky pic's in the meantime
https://www.s2ki.com/s2000/gallery/a...r-bottle-pump/
Wobbly
Jan 17, 2016 01:12 PM
Kris-S2k
Jan 16, 2012 09:00 AM
