headlamp washer pump replacement
Old Mar 26, 2013 | 07:15 AM
NB2004's Avatar
Default headlamp washer pump replacement
Hi guys, I need to replace the above as well as the pump for the screen washer for my MOT, I have found a few threads re the screen washer, which looks like an easy(ish) fix with a halfords part but I cant find anything on the headlamp washer. Does anyone know if this is a fairly easy replacement and whether its a generic part I can pick up? any advice much appreciated. Thanks
Old Mar 26, 2013 | 07:56 AM
earl's_f20c's Avatar
I've replaced both pump motors on mine; the windscreen one is a doddle and can be sourced easily as you say.
The headlight washer pump motor however was a complete bugger, it's the big jobby that sits above the small windscreen one and looks like this.
I bought mine 2nd hand from a forum member and it's still working.
To replace it was a knuckle scraping swear fest, I wanted to remove the reservoir to make the job easier but there's a screw that can't be reached without (I think) removing the wing.
So in the end I just bodged/twisted/scraped it in with brute force
Good luck OP and if you find a shortcut/decent method etc please share
Here's some mucky pic's in the meantime
https://www.s2ki.com/s2000/gallery/a...r-bottle-pump/
Old Mar 26, 2013 | 08:00 AM
NB2004's Avatar
Thanks thats a great help. Honda wanted £370 to do both, maybe I should have said yes! I'll let you know how I get on. cheers
Old Mar 26, 2013 | 08:02 AM
NB2004's Avatar
Just one other question, Honda talked about the motor needing replacing, is the pump and motor one and the same thing do you know? I assumed it was....
Old Mar 26, 2013 | 11:38 AM
Yikes that price made the knuckle scraping seem worthwhile
Yes they are an integral unit
Old Mar 26, 2013 | 11:47 AM
NB2004's Avatar
yeah think I will give it a go. cheers again
andylong
Apr 15, 2025 02:48 AM
Wobbly
Jan 17, 2016 01:12 PM
mattr
Jul 22, 2014 11:55 AM
Kris-S2k
Jan 16, 2012 09:00 AM
Armand
Oct 16, 2007 12:06 PM
