Setting alarm with roof down
Old 08-28-2004, 02:33 AM
tim_d's Avatar
Thumbs up Setting alarm with roof down
Hi,
I've tried a search on how to set the alarm and disable the motion sensors and found that I should be able to set the alarm (4 flashes of indicators) and press the button again (a further 3 flashes), for some reason this doesn't work for me. If I press the button twice nothing appears to happen the second time. Any ideas on what I'm doing wrong??
This is the keyfob I have:
.. which I believe is the Honda Cat1 alarm (says so on the plipper anyway! )
TIA
Cheers,
Tim.
Old 08-28-2004, 07:00 AM
hazdjc's Avatar
First press should be 4 flash's and then press again within 3 sec and you should get 3 flash's and bingo should be done.
Dave
Old 08-28-2004, 07:08 AM
steve_the_greek's Avatar
Have you got a hardtop ?
If not, then there is a switch hidden in the roof mechanism that auto-disables the ultrasonics when the roof is down, so you don't need the second plip. That might explain why you don't get any extra indicator flashes.
Old 08-28-2004, 07:15 AM
tim_d's Avatar
Umm, the car was orignally a roadster, but it's had a hardtop fitted by a dealer before I got my hands on the car.
Switch in the hood makes sense - thanks. Seems to be working fine now..
Elijah
03-17-2007 10:15 AM
CiderBoy
01-23-2007 09:12 AM
hornyhonda
08-04-2004 05:02 AM
markS2kcU
05-31-2004 03:15 AM
moff
02-04-2004 09:18 AM
Quick Reply: Setting alarm with roof down
