Rear Replacement
Old Jun 4, 2009 | 04:45 PM
S2KPC's Avatar
Default Rear Replacement
Just tore up my driver-side rear tire. Had a screw in it and it went flat ruining the sidewall. Wasn't driving fast (65mph) for about 8 miles and couldn't really tell that it had gone flat ... except that the S2K would pull to the left when I accelerated. Thank God we weren't out pushing it on a twisty mountain road (which I had been doing a couple of days ago).
I have 12K miles on the tires and the rear tread was at 6.5/32s -- so, about half gone.
Should I replace both rear tires or just the one that ran flat?
Also, would assume that I should put the same tire back on (OEM Potenza RE050) unless I want to upgrade all four.
Old Jun 5, 2009 | 06:24 AM
JP Money's Avatar
Replace both rears and you can go with a higher performance in the rear if you want imho. It would give you a little more understeer if anything. Jim can give you the best answer.
Old Jun 6, 2009 | 08:45 PM
S2KPC's Avatar
I went ahead and ordered two RE050s that will be here on Monday. Figure I'll put the old (good) tire in the garage as a spare in case this happens again.
cocogirl
Dec 10, 2010 03:54 PM
inuyashalover
South Florida
20
Jul 24, 2010 05:41 AM
ragamuffin
Feb 3, 2006 07:23 AM
jimi
Mar 24, 2004 04:20 PM
Texas redliner
Jul 11, 2002 10:38 AM
