Wheel Fitment Guide
Originally Posted by attilden' timestamp='1476239100' post='24082065
I have a 2000 ap1 with lowering springs. I am trying to get a new set of wheels a found a set of koenig feather blacks with 225 45 17 tires on all four. Anyone able to confirm if these will fit??? Thanks!
17 in x 7.5 in
Originally Posted by Breyeun' timestamp='1476240263' post='24082075
[quote name='attilden' timestamp='1476239100' post='24082065']
17 in x 7.5 in
[/quote]
Also I think the offset is 45 but not 100% sure. So to recap. I have a ap1 with I believe the tein 1" lowering springs that I want to confirm will fit Konig Feather 17x7.5 with 45 offset wheels with 225.45.17 all the way around. Thanks guys!
We need to know the offset and width. I can't find specs on those wheels since they seem to be discontinued by Konig but if I remember correctly they only came in 7 inch wide which is very narrow for the rear especially. Since you have an Ap1 you want more grip int he rear due to the car being tail happy from the suspension bias. You will want to try and match your wheels specs to AP2 OEM wheels or wider and the offset will determine if you need to roll your fenders.
Did you see my second post with the specs?
It doesn't really change the overall advice. 7.5" +45 wheel and 225/45 tire on a lowered car = fender roll in the front. It would probably not need a roll in the rear, but as mentioned you should really be looking for 8.5"+ width wheel for the rear.
hey guys,
My current set up is lowered and staggered with RPF1 17x8 front +45 offset and 17x9 +45 offset. Tires are 215/45/17 and 225/45/17. I think current set up is fine.
I'm thinking of going with PF01 17x8 front +50 offset and 17x9 +60 offset.
What tire size should I go with to prevent rubbing?
(if i'm reading the chart right, it says I can go with 275 tires with 9 inch width in rear... but not sure if going with that will cause rubbing... In front i'm going to stick with the same size 215/45/17)
If i go with 255 rear tire, would it leave gap or something ?
thanks in advance
thanks in advance
