Wheel Fitment Guide
Old Oct 24, 2016 | 09:53 PM
  #1281
s2000Junky's Avatar
Originally Posted by skytree
hey guys,
My current set up is lowered and staggered with RPF1 17x8 front +45 offset and 17x9 +45 offset. Tires are 215/45/17 and 225/45/17. I think current set up is fine.
I'm thinking of going with PF01 17x8 front +50 offset and 17x9 +60 offset.
What tire size should I go with to prevent rubbing?
(if i'm reading the chart right, it says I can go with 275 tires with 9 inch width in rear... but not sure if going with that will cause rubbing... In front i'm going to stick with the same size 215/45/17)
If i go with 255 rear tire, would it leave gap or something ?
thanks in advance
Your going to be sitting 5mm less aggressive up front and 15mm less aggressive in the rear on your new wheels. 255 would be the recommended tire size for the rear on a 9" wheel regardless of offset if you want a good sidewall/tire shape for good handling. A 275 would be pinched on a 9" wheel and not a good choice with overall diameter increase.
Old Oct 25, 2016 | 11:56 AM
  #1282
skytree's Avatar
Originally Posted by s2000Junky
Originally Posted by skytree' timestamp='1477372260' post='24091338
hey guys,
thanks in advance
Would you recommend 255/40ZR17 or 255/45ZR17 for the rear?
Old Oct 25, 2016 | 12:14 PM
  #1283
1nate7's Avatar
Keep your current wheels, roll the fenders, move the 225/45 to the front and get 255/40 for the rear.
Old Nov 5, 2016 | 02:35 AM
  #1284
Toms1989's Avatar
First off apologies if this has already been answered, Can't get to grips with these VBulletin pages!
Got some PF01's. 17x8 +50 for the front and 17x9 +60 for the rear.
Is the general consensus tyre wise to go for 225/40 for the front and 255/40 on the rear?
I am only lowered on eibach springs and have OEM geometry and I don't want any scrubbing!
Thank you in advance
Old Nov 5, 2016 | 02:55 PM
  #1285
Manga_Spawn's Avatar
Site Moderator
No because the right sizes are 225/45/17 and 255/40/17. They should be fine since you aren't that low.
Old Nov 6, 2016 | 08:41 AM
  #1286
Toms1989's Avatar
Thank you for that
Am I right in thinking these are the sizes the CR has fitted as standard? Dont get CR in the UK
Old Nov 6, 2016 | 12:57 PM
  #1287
1nate7's Avatar
Stock CR front is 215/45. I'd stick with the 225/45 front on a 8" wheel unless you think you will need the extra fender clearance of the 215.
Old Nov 10, 2016 | 12:17 PM
  #1288
dv55xc's Avatar
Default Tc105n 17x9 +49 with 245/40/17 square
Would Tc105n 17x9 +49 with 245/40/17 square fit on my car at stock height without a roll or relocation? what about if I decide to lower my car?
Old Nov 14, 2016 | 08:35 AM
  #1289
Site Moderator
It won't fit in the front. You will need a roll. Rears you may be ok depending on camber.
Old Nov 20, 2016 | 11:51 PM
  #1290
Toms1989's Avatar
Thought I'd follow up on my question about tyre sizes.
Fit perfect in the arches with no scrubbing and look mega
Can't wait to get this AP racing bbk behind it!
