Wheel Fitment Guide
Old Jul 25, 2017 | 12:41 PM
  #1421
Manga_Spawn's Avatar
Site Moderator
The BBK fitment will depend quite a bit on the wheel design not just the offset. With an added 25 mm fenders you have a lot of choices. I run 17x9 +43 in front and 17x10 +35 in the rear with Downforce front fenders and ASM rear overfenders. I have also run 17x10 +35 with a 255 all around on this setup and both fit over my brembo's. I would look at 17x10 wheels and keep the offset in the +35-45 range. You can fit a lower offset in the rear than the front in all cases. As for BBK clearance you have pick a specific wheel and specs and then find out the clearance.
Old Jul 29, 2017 | 11:40 AM
  #1422
panda25's Avatar
Will these specs fit ap1 without mods?
17x7.5 42, 17x8.5 50 with 215/245 tires?
interested in the new enkei nt03rr wheels.
Old Jul 30, 2017 | 09:09 PM
  #1423
Site Moderator
If you are at stock height maybe. Lowered they require a roll.
Old Aug 1, 2017 | 07:33 AM
  #1424
jay.algier's Avatar
Thanks alot I appreciate the advice! Im planning to go with evs fronts, voltex rears, and ce28ns so ill try to keep it x10 +35
Old Aug 1, 2017 | 09:48 AM
  #1425
P1h3r1e3d13's Avatar
I need all four OEM center caps. I see a few sets like this, but I don't know what size I'm looking for. Are they 64mm and 70mm like the bores?
Old Aug 1, 2017 | 01:53 PM
  #1426
Kami Speed's Avatar
Where are you getting those sizes from? According to the Enkei chart they dont make those sizes.
I see on the Enkei chart this is the closest to S2000 spec for the new Enkei NT03-RR
17x7.5 +50 Front
17x9.0 +63 Rear
This spec can fit with 225/255 without any modification to fenders.
Old Aug 1, 2017 | 04:26 PM
  #1427
Site Moderator
17x7.5 +50 Front
17x9.0 +63 Rear
As long as you aren't lowered much they don't.
Old Aug 1, 2017 | 07:28 PM
  #1428
panda25's Avatar
i must have been half asleep while reading the enkei chart, lol thanks! will you guys be bringing these in?
Old Aug 2, 2017 | 04:22 AM
  #1429
CMK's Avatar
CMK
They're special order, so you'll have to wait. I'm currently only 1/3 of the way to delivery of my Works...
Old Aug 2, 2017 | 07:21 AM
  #1430
Kami Speed's Avatar
Yeah that spec will have to be special ordered. Special Order Enkeis take around 2-3 months to come into the states. Let me know and I can order you a set. Only need 50% down.
