Wheel Fitment Guide
Old Apr 25, 2009 | 07:24 PM
  #471
srg23's Avatar
i see. very cool, early in my highschool career i wanted to be a mechanical engineer, but now im finishing up my senior year and kinda leanin more to business finance.
well i guess i should stop taking this thread off topic
Old Apr 28, 2009 | 06:18 AM
  #472
srg23's Avatar
hey spa-zz one more quick question:
can i add more negative camber with the car being stock (no coilovers or camber kits)?
i tried searching but havent found definite answer, so i thought may as well ask you
Old Apr 28, 2009 | 11:29 AM
  #473
spa-zz's Avatar
Yes, the S2000 suspension is fully adjustable, within limits of course. However adding negative camber just to make wheels fit is not prudent, IMO.
Cheers,
Ken
Old May 4, 2009 | 11:06 PM
  #474
youngcow's Avatar
Hey guys, if I got a rim that was a little bit below the minimum recommended offset, but it's staggered 7 front, 8 rear or 8 front, 9 rear; Could I just add wheel spacers to add more to the offset? Would this work? or will there be problems I dont know about? I'm thinking bout getting ether the xxr 006 or the raze r74 wheels but the offset is below the recommended. any help please? I want to run atleast 215-225 front and 255's rear.
Old May 5, 2009 | 03:26 AM
  #475
spa-zz's Avatar
Wheel spacers reduce offset. You need to increase it.
Let us know what offsets the wheels have.
Old May 5, 2009 | 04:59 PM
  #476
youngcow's Avatar
The xxr 006 is 17x8 front +35mm 17x9 rear +35. or if i wanted the red lip one it's 18x8.5 front 18x9.5 same 35 offset. The Raze R74 is 17x7 +42mm and 17x8 48mm. I was thinking of getting wheel hub spacers to increase the offset ether by 15mm or 25mm.
Old May 5, 2009 | 05:05 PM
  #477
spa-zz's Avatar
Forget it, man. 35 is way too low. It takes a lot to make that "fit", if you could even call it that.
As I said in my first response, spacers decrease offset. You need to increase it.
Old May 6, 2009 | 03:21 PM
  #478
metros's Avatar
Read through a lot of the thread and want to make sure I have it correct.
I want a set of 5zigen fn01r-c.
My goal is 225/45/17 tire in front and 255/40/17 tire in the rear. The car will eventually be lower than stock.
My wheel sizes should be 17x8 +58 (or higher) on the front and 17x9 +50 (or higher) on the rear.
Will this fit without rubbing and is this a safe bet that they'll still fit correctly with a lower ride height?
Old May 7, 2009 | 05:26 PM
  #479
metros's Avatar
Bump!
Looks like +48 is the highest offset they make in these wheels. How are the other s2ki members fitting these wheels?
From my calculations using
17x8 +43mm = 12mm closer to fender= .47 inches closer to fender. That seems like it should fit.
17x9 +43mm = 22mm closer to fender than stock = .86 inches closer to fender. Again that seems like it should fit without issue.
Any opinions from the gurus? Spa-zz?
Old May 8, 2009 | 04:58 PM
  #480
spa-zz's Avatar
They fit by rolling fenders, adding negative camber, running narrow tires, etc. You can do that, if that's what you're into. Rolling fenders is OK, but to me, changing alignment settings to fit some low-offset wheels isn't wise.
Lots of people have rubbing and they just deal with it because they want the look. Oh look! My fender liner has a whole in it! HAHHAHAA LOLOLZORZ!!!11
