Engine mounts
Old Nov 6, 2011 | 01:30 AM
  #41
jooboo's Avatar
No ones used hard races mounts?
Old Nov 6, 2011 | 02:14 AM
  #42
MAD828's Avatar
I have hardrace engine and tranny mounts and the diff mount front and rear. Much more direct feel without overbearing NVH levels as I have experienced with stiffer mounts in the past I'd recommended them.
Old Nov 10, 2011 | 09:57 PM
  #43
meccjoo's Avatar
awesome.
anybody know a good place to buy these?
Old Nov 13, 2011 | 07:08 PM
  #44
F20Chris360's Avatar
The clutch could be responcible for a lot of your problems. Ive had success with the innovative mounts. I've never ran them in my s2000 but i have them in my civic after going through a couple stock mounts and haven't had a problem yet. Ride quality wasn't effected either.
Old Aug 27, 2015 | 07:03 PM
  #45
Kid_s2kcr's Avatar
Thread revival
Anyone running solid mounts? Where did you get the from? Is the vibration barable?
Old Aug 28, 2015 | 08:27 AM
  #46
spdracerut's Avatar
Originally Posted by Kid_s2kcr
Thread revival
Some info on the Hasport mounts. I had to raise the idle speed up to 950rpm:
http://www.motoiq.com/MagazineArticl...rivetrain.aspx
Old Aug 29, 2015 | 11:40 AM
  #47
Kid_s2kcr's Avatar
I'm looking for solid mount with no bushings. The turbo setup I'm wanting to run gets really hot and I don't want it melting the bushing or take the chance of it happening.
Old Aug 29, 2015 | 02:42 PM
  #48
Bullwings's Avatar
Thread revival
If you have to ask, then absolutely not. I just put in megan racing mounts (same thing as the hard race mounts - look identical. I also know that a number of hard race/megan racing parts come out of the same factory - like their offset ball joints/RCA, they even have the same part numbers 6622 and 6621).
As far as vibration and noise - the change from stock was startling at first. I'm on stock intake, OEM-cat back, and a 63mm HFC to mate up with OEM header and exhaust. I pulled out a decibel meter, and inside the car at idle is around 80-85db - that's enough to cause permanent hearing damage over sustained periods. At WOT under vtec (5800+ rpms), interior cabin noise is at 91-92 db and the way things vibrate inside the car is definitely different. I drive with ear plugs now. The amount of vibration is like a "massage chair" to quote a friend who sat in the passenger seat.
That said, i'm fine with it; however, I would not go any stiffer than that for a street driven car. In fact, even if this was a track only car, I don't think I'd go solid mounts for either motor or trans mounts.
I've had them in for around 300 miles now, so I expect that there is a slight break in period, but I wouldn't expect it to change that much.
Edit: the Megan Racing / Hardrace motor/trans mounts are considered "Hardened Rubber." I believe the OEM motor mounts are fluid filled.
Keep your heat shields on, wrap your header, and get a turbo blanket.
Old Aug 30, 2015 | 05:08 AM
  #49
SmokeyGatto's Avatar
running megan solid rubbers. not too extreme, I've taken them drifting, put idk, 2000 track miles on them. zero issues. 40K street miles in addition.
Old Sep 2, 2015 | 02:09 PM
  #50
APoner's Avatar
Originally Posted by jon3501447
Originally Posted by psychoazn' timestamp='1310060257' post='20756086
I've had a few engine mounts replaced under warranty, and am going to need to replace my current ones as well.
Any recommendations on aftermarket engine mounts and/or success stories? My car is daily driven and sees 1-3 track days a month. I'm open to some extra harshness as my tolerance seems to be a tad higher than the norm, but I'm not looking to make the car feel like a full on race car, yet
I do believe the excessive wear is a result of a combination of my own driving habits (occasional hard shifting when I'm on a particularly good hot lap) and the ACT HD-SS clutch setup; I've had the clutch since the car was new. Going through mounts seems to be more common with grabbier aftermarket clutches (although the correlation may be coincidental).
Thanks guys!
Hey Mike-
After ripping my stockers several times I got fed up. But I didn't want to deal with the hassle of the 60a wearing too quickly or 75s vibrating like a solid metal mount. So I installed Megan Racing polyurethane mounts. The throttle response and throttle blipping is a MUCH more direct feeling; yet I haven't had a single wear issue so far. There IS a very minor idle vibration that I've grown to love. It's one of those things that always keeps you aware that everything is buttoned down tight.
Id did the same after the first time i ripped my mounts. The megan racing mounts are great, minimal vibration and noise (most people dont even think i have mounts) I track my car regularly and beat it with 440whp. I recommend them anytime someone asks about mounts. They also helped me with stubborn gear shifts at high loads on sweepers. I also dont get gear shifter slop or play since everything is nice and tight.
JonUKS2000
May 28, 2011 03:18 AM
Putney
Apr 17, 2011 04:12 PM
i2ichal2d
Jul 23, 2005 11:39 AM
lamvu
Sep 13, 2004 07:48 PM
Random1
Jun 17, 2004 06:36 PM
