Alabama S2000 Owners Club Areas including Huntsville, Birmingham, Florence, Decatur, Anniston, and Tuscaloosa
sub
Old 02-26-2008, 02:33 PM
codeman's Avatar
Thumbs up sub
What is the biggest sub you can put into a s2000 I say all you need is like one 10
Old 02-26-2008, 02:39 PM
apextamer's Avatar
It depends on how much trunk space you are willing to sacrifice. the most common is to use a 10" and build a custom enclosure in the tool/ jack well ( look into JL stealth box for ideas) or a custom enclosure that takes up the small space on the drivers side of the trunk. With the second option you need a subwoofer that requires low airspace to be most efficient. A 10" is more than adequate for the small area you are working with. A 12" is possible but keep in mind without the addition of headrest speakers you are only working with 2 front speakers ( or 4 if you inlude the tweeters with components) A 12" usually in that scenario is overkill.
Old 02-27-2008, 12:51 PM
compS2000's Avatar
My S2000 has a 12" sub in the trunk, it takes up the entire well plus an extra 3" tall, including the long throw Sub Grill, i can take a picture of if you want, it came with the car when i bought it but the amp was trashed and had to be repaired. It really cranks and proably is a little much. I find that an 8" sub for the size puts out better sound than a 10" is you search the forum they have some neat designs for subs on the sides of the trunk so you do not loose the wheel well. I have also seen a really neat design by Modifry on the passenger side floor.
Old 02-27-2008, 12:52 PM
compS2000's Avatar
and i do have after market fronts that are also amplifie and capped off with a crosover, otherwise the bass would over power. I can contorl the amp with a remote sensor as well.
Old 02-27-2008, 12:56 PM
Kermdaddy's Avatar
I have two 12" subs and amps if you are interested. It was listed in the for sale section a week or so ago.
Old 02-27-2008, 04:57 PM
hondafied's Avatar
im gonna go with a 8" in the passenger footwell after i figure out how to make a box that fits
Old 02-28-2008, 07:37 AM
MugenRioS2k's Avatar
I have what would be equivalent to somewhere between a 12" to a 15" sub.
Boston Acoustics 555
Old 03-05-2008, 02:48 PM
westmobs2k's Avatar
ive got a six on the floorboard... sounds great
Old 03-05-2008, 02:53 PM
RBC3's Avatar
PICS!
Old 03-05-2008, 04:31 PM
gregnm369's Avatar
old thread from the MR-S forum, but this is their solution. I am still listed as a moderator of the audio forum :-) Back then, I was simply known as NM369.
http://spyderchat.com/forums/index.php?showtopic=24398
hobbes
03-29-2012 08:26 PM
s2kdarren
05-10-2006 05:52 PM
civicguyinva
03-01-2006 08:39 PM
SD1S2K
05-08-2003 11:19 AM
WLAURENT
05-21-2002 10:26 PM
Quick Reply: sub
