Broken valve cover bolt
Old 05-11-2008, 06:51 PM
ahbongkadah's Avatar
Default Broken valve cover bolt
I was installing an intake on my friends gs350, and the mounting bracket goes on the valve cover bolt. While putting the bolt back on, I over tightened it and it snapped off
How can i remove the remaining part of the bolt? It is too low to grab with a vise grip.
The hole goes through if that makes any difference.
Thanks in advance for your help!
Old 05-11-2008, 08:38 PM
sharkbite's Avatar
what year, what engine?
Old 05-11-2008, 08:45 PM
its a 2007
It is the standard v6 engine in the gs350
Old 05-11-2008, 11:55 PM
slightly2ned's Avatar
You need to get a bolt extractor bit. You attach it to your drill, set it in reverse & drill a small tap hole. You then flip the bit & extract it with the tool. Cost around $15-$20 at a hardware store.
I once stripped the head of an allen on my steering wheel/quick release setup & this is what I used to remove the stripped bolt head. Same principle for broken off head, as long as there is surface to work on.
Old 05-12-2008, 05:56 AM
rockville's Avatar
Can you just pull the valve cover then grab the remnants of the bolt?
Old 05-12-2008, 07:05 AM
2poor2mod's Avatar
exactly what i was thinking
Old 05-12-2008, 07:41 AM
Removing the valve cover on this car would be a lot of work. There is so much stuff on top of it, i wouldnt know where to begin haha.
Thanks for the help. Looks like i'll have to use an easy out. I was really trying to avoid it though
Old 05-12-2008, 07:42 PM
Mr.E.G.'s Avatar
do yourself a favor and dont buy the black and decker bolt extractors. i broke three in a row while using them properly and trying to extract a fairly non rusted bolt. i went and bought a good set and it worked like a charm.
good luck.
S2kbryan
04-07-2014 10:16 AM
Mallain123
06-19-2013 08:15 AM
mnr12
05-22-2010 06:57 AM
chudc
05-18-2004 05:25 AM
Squeezer
02-21-2003 08:35 AM
Quick Reply: Broken valve cover bolt
