Warm Idle Adjustment Screw
Old 12-13-2005, 05:26 AM
spidale5's Avatar
Default Warm Idle Adjustment Screw
My Accord's warm idle was fluctuating from 700 - 2000 rpm, in a pretty quick cycle. I did a little research and began to listen for some vacuum leaks. Sure enough, the warm idle adjustment screw had worked its way out, almost to the point of falling onto the ground. I screwed the screw back into place, and adjusted the warm idle back to spec. Everything was back to normal.
I arrive at work this morning, and the symptoms are back. The screw had worked its way out again. My question is basically this:
How can I stop that screw from working its way out again? I don't want to just Loctite it into place making future adjustmnets impossible, but I do want it to stay tight. Any ideas?
Thanks,
Tony
Old 12-13-2005, 05:28 AM
spidale5's Avatar
Thought I was posting in Car Talk, please move.
Thanks,
Tony
Old 12-13-2005, 07:11 AM
dhayner's Avatar
Blue Loctite
Old 12-13-2005, 09:20 AM
spidale5's Avatar
Thanks, I'll give it a try!
ans2k
02-24-2010 06:00 AM
combats2000
12-06-2008 03:59 PM
hondadcw
10-22-2008 08:18 PM
S~Factor
19
04-17-2008 08:28 AM
Phatmo111
07-30-2006 10:30 AM
Quick Reply: Warm Idle Adjustment Screw
