spun rod bearing
#31
#32
Get the car to Jason (CNC Speedshop). He can diagnose and repair...be expecting a few thousand though, as the motor may need a rebuild. If there is anything you've been wanting to do to boost performance, go ahead now....the block needs to be opened and redone.
#33
When you spin a bearing, the big end of the rod distorts, so you MUST replace the rod. Polishing the crank does nothing for it being out of round. When you spin a bearing, you should be replacing the crankshaft and the rod it spun on... As well as the oil heat exchanger.
#34
Originally Posted by EF'n Chris' timestamp='1341972069' post='21849831
Did you ever get a engine oil light while the car was running? Does your car shut off on low rpm's randomly after a coast?
