ASM Overfenders
That's a super easy fit in the rear. Just roll/relocate/trim and add a little camber and it should fit fine on stock body. If you have clearance issues after that, just pull the rears a little. The closest thing to rubbing will probably be right where the rear fender meets the bumper.
for all the guys with the non-stag concave CE, which would fit better with the ASM front and rears? 17x9.5 et35 or 17x10 et45? i was doing a little bit of research and people have been saying 17x10 et45 would fit better...im trying to get it as flush as possible with minimum to no poke and with little to no camber (maybe enough camber where i dont rub or have to change out my tires every 2mons)...yeah im weaksauce hahaha just dont wanna go through so many tires since its my daily...any recommendations will help...thanks
edit: tire size im thinking about is 245/40 for 9.5 and 255/40 for 10 ^__^
I would like to run 18x9.5 or even 18x9.5 up front and 18x10 or so in the rear. I am getting coilovers and the Downforce front wide fenders (+30mm wider) and want the ASM rear overfenders. I want to get the Volk TE37s in bronze. Any recommendations? What tire size etc? Also any shops in the MD/DE/PA/NJ area that has installed these????
Don't have ASM over fenders but would like to eventually run them down the road with the wide 08 bumper. I have 17x9.5+35 in the rear but would like to run a 255/40 or 265/40 if possible. Would this work with the overfenders and would I need to trim them to fit the 265s and guarantee no rubbing?
