Sponsored by: Sake Bomb
Unknown rear occasional clunk...possible culprits?
Old 04-08-2019, 09:57 PM
fat_louis's Avatar
Default Unknown rear occasional clunk...possible culprits?
Hi everyone
I have been sorting through my new to me 91k mile 2006 ap2.
On occasion i hear a clunk coming from the rear of the car possibly towards the drivers side.
At first i thought it was the spare so i opened the comparrment up and made sure it was secured properly.
It does not seem to be a suspension piece because i dont hear it all the time.
I am thinking some sort of driveline mount that is worn out causing something to hit the body when transmission shifted under load.
Any ideas?
Thanks!
Fat lou
Any ideas
Old 04-09-2019, 07:44 AM
s2000Junky's Avatar
You will get a clunk in the drivetrain picking up slack changing from reverse to forward if you are not mindful. Its not abnormal, but it can be avoided in how you clear the transmission and operate the clutch. Not rushing is usually part of it. I rarely if ever hear this, so am not even sure if I could recreate it at this point, but others driving habits do. Its possible this may be what you are hearing.
Old 04-09-2019, 07:49 AM
Car Analogy's Avatar
Received 1,346 Likes on 1,013 Posts
The toolkit for changing tire? Its in the well.
Remove everything from trunk, then see if noise goes away.
Maybe the fuel filler neck is loose. Remove liner, feel around for anything loose.
Also, feel around on 5e suspension for anything loose. Could be as simple as a worn out swaybar end link.
Old 04-09-2019, 08:11 AM
B serious's Avatar
Received 1,282 Likes on 963 Posts
The cure I usually find effective is checking the source of the noise and then fixing it.
Joking aside, sway bar links are a common source of clunks. Disconnect (unbolt) one of the 4 link points. zip tie the link to the bar or LCA so its not flying around. Go for a drive.
Noise gone?
If yes, you found the issue.
If no, then you know the links are likely OK.
Old 04-09-2019, 08:21 AM
engifineer's Avatar
Received 1,224 Likes on 946 Posts
And a sway bar with tiniest, almost indetectable amount of slop in the endlink will sound like a control arm is about to fall out of the car :P
fat_louis
04-14-2019 07:14 PM
8000RPM
04-06-2010 03:33 PM
TDokmo
08-03-2008 09:02 AM
Amer
02-08-2006 05:34 PM
Sideways
11-11-2002 11:20 AM
Quick Reply: Unknown rear occasional clunk...possible culprits?
