Alpine type-X 6.5" Components
Old 11-14-2005, 01:46 PM
DC2
DC2's Avatar
Default Alpine type-X 6.5" Components
Will these fit in my '05 with little to no hassle, or will it have problems with stock size and mounting depth?
Thanks in advance.
Old 11-14-2005, 02:42 PM
JawKnee's Avatar
Odds are that you will have to make your own "spacer/baffle" or modify the existing stock basket to accomodate the new speaker. However, it's really quite simple and not that big of a deal at all. I modified the stock baskets with a Dremel in little to no time. I believe there are some speakers that will be a direct drop-in or require very little hacking of the basket, but I don't know which ones off the top of my head.
Do note that you may want to protect the rear/magnet of your mid with either approach as the rear will now be exposed. I used XTC Baffles and essentially cut most of the back off leaving enough to function as an umbrella. Otherwise, the sound will suck and you could potentially damage your speaker with an unmodified XTC baffle since you would be making the speaker work in an enclosure when it shouldn't be.
Old 11-14-2005, 03:56 PM
darkknight1999's Avatar
I have the Alpine type-x speakers. You will need to trim the back off the stock basket and if you use your car as a daily driver you should as Jawknee said protect them.
Old 11-14-2005, 03:59 PM
BTW sorry the pictures are so bad... course those are about 3 years old with a camera I had just bought.
Old 11-15-2005, 10:15 AM
DC2
DC2's Avatar
That's more information I need. I appreciate it alot because I was very concerned on the mounting depth and it doesn't look like a alot of room there. Those pics give me a great idea what I'm in for.
Thanks guys!
Old 11-15-2005, 10:33 AM
boyguan's Avatar
there is alot of depth back there
just as long as you cut the backing out
Old 11-15-2005, 10:39 AM
jwa4378's Avatar
Actually, there is not that much room. There is only like 1.79" from the interior side of the door frame to the window track. Many speakers with LARGE magnets / deep mounts will just not fit without a spacer.
John
Old 11-15-2005, 03:12 PM
boyguan's Avatar
i fit my pioneers which are 2 3/4 i believe
infinit kappa are about the same
i still have plenty of room. i just reuse the stock spacer and cut out the backing.
one more option is if you still dont have enough
remove the front stopper of the glass.
Old 11-15-2005, 05:41 PM
You really should just leave the window alone, there's really no need to touch that. Just add another spacer made from MDF.
Old 11-15-2005, 06:17 PM
jwa4378's Avatar
w/Darkknight. I was referring to the interior sheet metal panel to the window frame. That was not including the stock bracket (which some speakers will not fit into). I was simply stating that some speakers with deeper mounting depths will not fit into the stock spacer, and will not fit in unless some sort of spacer is made. I just made this comment, as I think he is referring to a set of pretty much drop-in speakers. Just stating that all speakers that are "6.5" are not always going to fit.
Either way, its just as easy to make an MDF spacer .
John
Elysian
12-22-2013 06:34 AM
MrYellow66
11-30-2010 05:16 AM
Ricgreen
06-03-2007 11:51 PM
sleeze
12-09-2005 12:29 PM
jal3lee
08-04-2005 12:34 PM
Quick Reply: Alpine type-X 6.5" Components
