Elemental Designs GB - Testing the water
Originally Posted by pikkashoe,Dec 4 2004, 08:25 AM
I can testify for our SS Van gogh, that if you run the sub parrallel and drop it down to 2 ohms bridged, the amp shuts off. I tried running my alphasonik 8inch dvc (4 ohm) in parallel and the amp would just cut off once you pushed the volume up.
Just need to be able to give it ~300Wrms @ 2ohms. - WLAURENT
Any possibility of a photo of your modified enclosure?
Based on your experience, should I run two 10s, one in driver side, one in passenger side? If so, I believe both would be DVC 4 Ohm as to wire each in series then parallel them into a 4 ohm final load on one bridged channel.....or just run one which would be DVC 2 ohm wired in series as a 4 ohm load?
If I start with one DVC 2 ohm sub, I don't think I can add another at a later date. I think I would have to purchase two new woofers as DVC 4 ohm based on Van Gogh desired loading characteristics. (If I run on the same single bridged channel)
Will the SPL be different if I run one vs. two on the amp's same 500 X 1 bridged output? (I still want to run the Kappa Perfects on the other two channels...) (If this is even allowed...)
Do you think the eD will fit in both the driver and passenger side enclosures?
Is this ridiculous?
Thanks,
Keith
I will get a picture up tomorrow
The sub will work in both the driver and passenger side enclosures.
The SPL will definately be greater with 2 subs. Not sure what to advise you to do. I personally think a single 10" is plenty. But that is just my opinion.
I am hoping to get something sorted out with eD and my fiberglass guy on Monday. I leave for New Zealand/Australia on the 14th and will not be back until January 5th.
Originally Posted by PJK3,Dec 4 2004, 03:49 AM
Jim -- is Karl our man that we were dealing with?
name sounds familiar....
Yes, this was our man. On a serious note, I would love to do a comparison on this sub. I will be able to compare against my recollections of RF HX2, JL 8W3v2, and now Alphasonik PSW 810.
William, you've got PM.
Jim
generally tho -- 1 10" at 500 Wrms should be more than adequate for most bass needs.
what's your final goal? hearing and feeling the sub? or are you wanting to get into the vision blurring range of bass?
Jim
ROTFLMAO!
i don't think Karl liked me...
Sounds like one 10 is a good start.
On the educational side of things..I just read my previous post and think I made a mistake, but I am not sure. If you have two DVC 4 ohm subs, would you wire each sub in parallel for 2 ohms then series the set to get 4 ohms...or...series the DVC 4 ohm to 8 ohms then parallel the set to get 4 ohms load? Will it sound different? (Just wondering....)
Also, I saw a JL 12W7 driven by a SoundStream VGA 600.2 in a photo on the 'Stereo Install Pictures Here' thread. See page 8 about 1/2 way down.
The 12W7 is rated at 2.47 ohms I believe. If so, the Van Gogh must be able to approach 3 Ohm loading sucessfully? (Or at least the 600.2 does...)
Just Wondering...
Just Wondering...
"ROTFLMAO!" ??? I'm behind again.....(No clue on this one)
Also, I don't think Karl likes anyone...
I didn't ask for him, he just picked up the phone when I called in.
Do they have anyone nicer there?
Jim - What did I get into here???
This seems to be the amp from &*##.
(It sure is fun though...)
. I didn't ask for him, he just picked up the phone when I called in.
Just Wondering...
Just Wondering...
