Ordered kapa perfect components, harness help needed
Old Feb 17, 2004 | 12:48 PM
  #31
NFRs2000NYC's Avatar
Just an FYI.....Optima are considered the best deep cycle batteries. However, they arent the only ones who make them. Lightning Audio, Stinger, along with other companies make them as well. So, use your judgement, the Lightning audio as pretty good IMHO.
As far as capacitors go....it has been from my experience, that they hurt the car's electrical system (sucking up juice that should go to your battery, while saving your amps. Unless you are running 80%+ gains, you dont need a cap, especially if you are running less that 650wrms of bass. Basically, in higher power systems in trucks and such, you are talking cars elecrical system damage vs. amplifier damage. In an s2000, a capacitor is nothing more than a parasitic paper weight.
Old Feb 17, 2004 | 02:06 PM
  #32
AndyS2's Avatar
Well how about I get capactiors and not connect them Ill just run some wires from the capacitor to the interior and no one would notice that I didint connect them.
About runnig wires,
is the best route trunk to the middle console to the headunit ?
for the speakers I am kinda confused how to run them to the trunk hidden.
however at the end I should have a wiring diagram which starts at the HU goes to the amps in the trunk and from the amps in the trunks goes to the speakers in the doors, ( and sub ofcourse) right? Am I gonna use the factory harness anywhere in this installation except power for the HU, Radio antenna and ground?
Do I have to run 2 power cables from the battery for 2 amps?
Old Feb 17, 2004 | 02:09 PM
  #33
AndyS2's Avatar
Oh wait a minute I for gat the corssovers, so its like HU to the amp to the crossovers to the speakers right?
Old Feb 17, 2004 | 02:21 PM
  #34
AndyS2's Avatar
So in this diagram, if blue is the HU, red is the battery, green is the amps, yellow is the crossovers and black is the speakers, are all the connections correct? Anything else needed?
Or should I run to the crossovers first and then to the amps so the amp doesnt have to amplify the signals which are going to be eliminated anyways?
Old Feb 17, 2004 | 03:54 PM
  #35
PJK3's Avatar
your setup looks good, except that w/ the wiring kit we recommended for you (the RF) - the amps will be supplied by a single power run from the battery to a fuse block, then from the fuse block to the amps. the distance from the fuse block (distribution block) to the amps will be less than 6 feet probably.
and the crossovers have to sit in between the speakers and the amp, like you have them drawn.
power goes down the right.
RCA's go down the middle.
speaker wires go down the center or the left.
amp turn on leads go somewhere w/ the RCAs or the speaker wires.
the ground(s) for the amp should tie in to the car at the trunk. we'll show you a good mounting point.
to hide the speaker wires, RCA's, and power in the trunk, this is what i did... i put my amps in the 'well', so i ran my wires down low, then cut a slot in the trunk liner and pushed the wires through. i then ran them under the liners into the spare area, and out.
where are you putting your amps again?
and finally,
you could use the factory harness for speaker wires - but if you're not lazy (like i am), run your own speaker wires from amps to speakers.
Old Feb 17, 2004 | 04:05 PM
  #36
AndyS2's Avatar
Amps will be on a rack in the trunkstanding horizontal in the trunk mounted to the back of the trunk(tire well area will be sealed).
amp turn on signal wire? That wire is provided with that rf set right?
So ok 1 power wire from the right side of the car splitting in to 2 for the amps from the fuseblock.
RCA's goes in the middle and they carry the sound from the HU to the amps.
Speaker wires carry the sound the the amps to the the speakers, but If I run them together from one side like left, how do I go from the left front side of the car to the right front side to the speaker? Go thru the dasboard?
Old Feb 17, 2004 | 06:20 PM
  #37
Honestly, this may arouse some debate....but...
I have my power on the right
RCAs and left speaker wire on the left.
Right speaker wire on the RIGHT.....right next to the power.
Perfect ground.
Absolutely no ground noise (aka alternator whine) I dont think that speaker wire gets affected by power....only the RCAs. But I dunno.
Also, it is almost impossible to have power and RCAs seperated 100%. With most amps, they meet up anyway (within inches).
Old Feb 18, 2004 | 05:59 AM
  #38
PJK3's Avatar
yup -- go through the dashboard. once you have the side panels pulled, you can shine a light from the driver's side and look from the passenger side - a clear passage will be visible for running wires.
turn on wire will be supplied w/ the kit.
given where you have the amps, i'd just run the wires either up and then under the rear panel or down and under the panel.
[QUOTE]Originally posted by NFRs2000NYC
hellspare
Nov 29, 2009 11:19 AM
VTEC 2 NV
Oct 26, 2009 12:29 PM
SilverstoneS2k_FL
Feb 18, 2005 08:21 AM
koala
Jul 24, 2003 09:24 PM
Josh and Jenny
Nov 24, 2002 06:29 PM
