S2000-specific Audio FAQ
Old Jun 2, 2004 | 09:37 AM
  #31
PJK3's Avatar
to be added to the FAQ:
what are amp gains? how do they work? what do i do if my HU outputs 8 V pre-amp but my amp only accepts 4 V?
the area of gains and inputs are really a very commonly misunderstood subject.
______________________________________
for a moment, work a rough analogy w/ me... let's think about us being outside in the afternoon (average lighting) and going into a building w/o windows and closing the door behind us. your eyes receive an input from the room's lighting output.
if it's really dark in the room, you're going to be blind in the darkness. the input levels in the room are too low for you to get a good signal. (this is what happens if your gains are set too low. amp is set for a 4 V input and you've got .5 V outputs from the HU)
if it's really bright in the room, you're eyes are going to be overwhelmed when you walk in... you'll be blind, but from visual overload. the input levels are way high for you, and so your visual signal is distorted. (this is what happens if your gains are set too high. amp is set for .5 V and you've got 4 V outputs from the HU OR amp is set for 4 V inputs and you've got 8 or 16 V from the HU.)
if the room is at a similar light level as the outside, when you walk in everything looks just fine and you see great w/o any distortion or problems. your input levels and the output levels of the room match... (this is what happens when your gains are set right. amp set for 4 V and HU outputs 4 V.)
now, of course, your eyes will adjust - but your amp's input levels will not.
along the same lines - the signal output by your eyes to your brain didn't increase or decrease based on the lighting of the room... but your perception of the signal did.
________________________________________
amps generally work in the same way.
sorta.
in an amp's case though, if you set your gains low you can reduce the power output by the amp. BUT setting your amp's gain higher than optimal DOES NOT make more power. this is why you can adjust your gains down slightly and run power slightly above the speaker's rated power. it's because by dialing the gains down, you're actually reducing the amp's output power before the HU starts to clip. (you're losing max volume)
so, in reality can you get away w/ the 8 V preamp outputs on an eclipse head unit w/ an amp that doesn't support them? yes, but you're also distorting the signal before you normally would when the HU's output voltage exceeds the amp's rated input voltage. it doesn't make the amp run cooler or make more power. the best thing to do in that case would be to install some signal attenuators to get your output signal to match up w/ the amp's input range... is it necessary? no...
Originally posted by PJK3
IF you have an 8 V or 16 V preamp output HU already or really want to use one, your best solution is to use an RCA level attenuator to step the signal down to an appropriate range for your amp's inputs.
http://www.partsexpress.com/pe/showdetl.cf...tnumber=266-240
http://www.partsexpress.com/pe/showdetl.cf...tnumber=266-242
http://www.partsexpress.com/pe/showdetl.cf...tnumber=266-244
generally speaking -- amp gains are not volume knobs... (there are exceptions... think Jensen etc.) turning the gain down means you're making the amp less sensitive. turning the gain up means you're making it more sensitive... sensitive to what? the input Voltage.
here's a detailed page all about amplifier gains and setting them: http://www.bcae1.com/gaincon2.htm
please take a few minutes to read this page as it is way enlightening, and not horribly technical. take special note of the shockwave / flash demo at the bottom.
note the first paragraph...
Contrary to popular belief, an amplifiers gain control does not determine the maximum power that an amplifier can produce. As long as the preamp/drive signal has sufficient level, the amplifier will produce its maximum power output level. The gain controls are used to match the amplifer's gain to the gain of the other amplifiers in the system (in the case of a multi-amp system). The gain controls also allow you to match the amplifier(s) to the head unit. Not all head units have the same maximum preamp output voltage. Some head units are capable of producing 9 vrms out while others are only capable of 1.5 vrms out.
quoting myself from this thread: http://forums.s2ki.com/forums/showthread.p...threadid=203883
what's the best way to set the gains on my amp? how do i set the gains on my amp?
the best way to set the gains on your amp is to use an oscilliscope, a spectrum analyzer, and test tones and use the method found here:
http://www.bcae1.com/settinggainswithscope.htm
a much more practical and still very good way to set gains is to do this:
taken and modified from Crutchfield's install advisor at: http://www.crutchfieldadvisor.com/S-m9SNHU...ifiers_faq.html
-Setting the "gain" or input sensitivity control is an important adjustment common to all amplifier installations. Proper gain setting helps reduce noise and distortion and allows for the widest possible dynamic range. Here's how to do it:
1. Turn your amplifier's input level controls all the way down.
2. Choose a CD to tune with and put it the player. You will want to use a very clear musical source, but one that covers a full range of bass, midrange, and treble. Distorted types of music are a very poor selection, as it will confuse your ears. Turn up your receiver's volume control. You'll begin to hear music at faint levels. (Audiophiles and sound competitors may want to use a dedicated test disc.)
3. Carefully listen for clipping distortion from the preamp of the Head Unit. Clipping distortion will sound like a blurring of the sound, not a mechanical popping or distortion, and it can be difficult to detect, so listen carefully. When you start hearing distortion, lower your receiver's volume control until the distortion disappears. This should be approximately 75% of max volume. (Multiply the max volume number by .75 to confirm this value.) There will be a few exceptions to the 75% rule, but there will be close to 1 in 1,000 odds. Consider this 75% number to be your new 'Max Volume" setting, as turning up the stereo above this level will only gain you distortion, but no further 'volume.'
4. At this point, you have as much signal as possible passing from your receiver into your amp. (This gives you maximum signal-to-noise ratio, so you'll enjoy clean sound and your system will be less prone to engine noise problems).
5. Now begin adjusting your amp's input gain. Turn the input level controls up until the system is as loud as you can stand it or until you begin hearing distortion
Old Jun 2, 2004 | 08:25 PM
  #32
b0mbrman's Avatar
Done
Old Jun 4, 2004 | 08:33 AM
  #33
PJK3's Avatar
thanks Mario.
Old Jun 16, 2004 | 02:29 PM
  #34
AquilaEagle's Avatar
Administrator
What a fantastic thread!! Thanks for all the work gone into it guys
Old Jun 16, 2004 | 08:42 PM
  #35
b0mbrman's Avatar
Wow, this certainly isn't current...
I'll be doing some research soon because I'll put a little bit of a system in my beater (probably just deck, fronts, and rears) so I can update a lot of the prices and deals over the weekend. Also, I'll work on incorporating more of the suggestions that I missed in this thread.
Old Jun 18, 2004 | 01:22 PM
  #36
TepEvan's Avatar
You need to add the #Running Wires for your S2000 system hidden bookmark to the bottom of the page.
Old Jun 18, 2004 | 01:24 PM
  #37
TepEvan's Avatar
here is a good Car Audio Document that I've used
Right Click and Save As
Old Sep 23, 2004 | 08:49 PM
  #38
jaws4096's Avatar
Anybody know if the enclosure at http://www.azcartoys.com/s2000.htm will fit a 8W7 subwoofer?
Old Nov 10, 2004 | 04:59 PM
  #39
PJK3's Avatar
won't fit -- depth is the issue.
Old Mar 23, 2005 | 10:01 AM
  #40
darkknight1999's Avatar
This thread has been lock for updating.
Stand by for Version 2
KaCee
Nov 24, 2004 02:03 PM
vrod
Sep 20, 2003 12:38 PM
petraidm
Jun 7, 2003 02:48 PM
Y2K++S2K
May 28, 2001 09:13 AM
