wth is wrong with my speakers?!
Old Jun 20, 2008 | 06:02 PM
Mother's Avatar
If it was a bad crossover it wouldn't have switched sides when he switched the wires.
Old Jun 21, 2008 | 04:54 AM
crdcz03's Avatar
Originally Posted by darkknight1999,Jun 20 2008, 12:01 PM
ok... so its not the cheap answer... to bad
Next you want to swap the RCA's. Just just move the red lead to the white and the white to the red. Could just be bad RCA's.
We have to test to see if its the RCA cable's, the amp or the HU.
Try that and report back
ok those are swapped and i will give full report when i drive home from work.
hopefully its not the HU b/c that part i actually like, the RCA's are relatively cheap and the amp was used anyways so even tho they are kinda expensive i wouldnt mind buying another one
Old Jun 21, 2008 | 06:57 AM
darkknight1999's Avatar
I hear that...
Old Jun 22, 2008 | 09:54 AM
crdcz03's Avatar
ok with the rca switch it has not changed sides.
Old Jun 22, 2008 | 03:00 PM
chickdr's Avatar
I think that makes the amp your culprit . Should be easy to replace as all the wiring is already in place- just get a similar sized amp...
Old Jun 22, 2008 | 03:05 PM
The amp could be the problem. I would check the ground location one more time before you run out and grab an amp. Make sure its a good one.
Old Jun 23, 2008 | 04:51 AM
crdcz03's Avatar
it is bolted down on that rear strut bar thing. ive sanded it down real good too b/c i had a problem with it earlier
if it were the ground wouldnt it do it to both sides?
Old Jun 23, 2008 | 04:56 AM
crdcz03's Avatar
i'll prolly go with something a little better. the one i have is only a 2 channel but i think i might add a sub to it here pretty soon
DuCKy!
Jun 21, 2015 06:24 PM
JD NC
Jan 31, 2013 06:12 AM
DSCLegend
Jul 29, 2010 09:33 AM
hariku821
Dec 3, 2008 04:31 AM
black s2k
Jan 1, 2006 04:58 PM
