Best intake setup for Vortech Supercharger?
Old May 28, 2012 | 09:23 AM
SgtDuracell's Avatar
Default Best intake setup for Vortech Supercharger?
Hi, I have a supercharged AP1 and currently have the filter on a 3.5" elbow off the blower. I was just given the vortech kit's heat sheild and am thinking about putting this on (as per kit specs ie blower -> elbow -> flexhose -> sheild -> filter) would this be the best setup? or has anyone found gains from using anything else? the flex hose would be a bit of an eye sore in my bay, but i think it'll be more efficient..
others have suggested putting a mushroom filter directly on the blower (HKS/Greddy Looking type) and others have suggested to just put a screen on the blower and run no filter/intake arm etc.
also, I plan on running about 15psi soon. would i have to change the setup to accommodate for the extra boost? move up to 4 inch maybe?
Thanks
Old May 28, 2012 | 10:44 AM
s2000442's Avatar
Look up sideways build he has and makes a custom 4 inch elbow and heat shield for the vortech
Old May 28, 2012 | 01:01 PM
Sideways's Avatar
There are pictures in the thread. You can copy it if you want a 4 inch intake. My supercharger is a T-trim and has a 3-3/4 inch intake. I necked the 4 inch 6061 aluminum elbow down with a silicone coupler to fit the supercharger. There are also 4 to 3-1/2 inch silicon couplers available for S-trim Vortech superchargers. I don't know the size of the comptech intake. Summit Racing has polished elbows very cheap. You need a 4 inch radius bend. The six inch will not fit. K & N makes many filters that will work.
https://www.s2ki.com/s2000/topic/634...#entry14384146
There is a large amount of cold air available where I have the intake filter. Air enters from the fender and around the radiator.
IMHO the mushroom filter on the supercharger is not a good idea.
Old May 29, 2012 | 11:02 AM
thx for the info. did you run the hose from the intake pipe to the manifold? (pcv?)
Old May 30, 2012 | 12:03 PM
Sideways, I'd like to know more about your setup (not just the intake but the whole motor) do you have a build thread? i'd be interested as to what you needed to make that amount of power with the vortech blower
thanks
Moddiction
Feb 7, 2010 04:17 PM
legendman
Nov 26, 2008 05:26 PM
Sideways
Aug 8, 2007 09:02 PM
o2s2ooo
Mar 5, 2007 09:15 PM
Sideways
Jan 7, 2007 08:01 PM
