CTSC dyno'd and tuned
Old Sep 13, 2008 | 11:19 PM
  #31
s2000Junky's Avatar
Originally Posted by S2k_RN,Sep 13 2008, 09:47 PM
Another question for everyone FI'd. Under partial throttle you should be running lean correct? And at idle it should be about 14 while under partial throttle it should be between 14-15? But once it hits boost it should be run rich.
Sorry for all the questions still a noob.
yes that is correct, at idle and partial throttle it should be a "stoitch" or 14.7 ratio. This number will hunt naturally so if you hook up a wideband to it you will see it sweep between 14.1 -15.1
Old Sep 14, 2008 | 06:49 AM
  #32
S2k_RN's Avatar
Thanks
Old Sep 15, 2008 | 08:17 PM
  #33
S2k_RN's Avatar
I was just thinking and searched around this site. My tuner recommended the precision 680cc peak and hold injectors which is what I'm using. I'm also using a resistor box with it. Could this be the reason that is causing my bog/hesitation?
Do you guys think going with a saturated injector will be better?
EOE
Dec 29, 2014 04:05 PM
myflys2k
Mar 12, 2010 05:45 AM
folex187
Oct 2, 2005 08:29 PM
spoiled@21
Sep 16, 2005 02:19 PM
skibum
Jul 10, 2005 04:13 PM
