engine failure pictures
Old May 18, 2014 | 10:14 AM
  #21
dan_uk's Avatar
looking at cyl #1 from the top (which was one of the most intact cylinders)
looks like its hit a valve on the top right?
[attachment=59146:IMG_20140518_132212.jpg]
This is the piston from cyl #3 where most of the action took place:
[attachment=59147:IMG_20140518_133901.jpg]
others:
[attachment=59148:IMG_20140518_133927.jpg]
[attachment=59149:IMG_20140518_133951.jpg]
Attached Thumbnails engine failure pictures-img_20140518_132212.jpg   engine failure pictures-img_20140518_133901.jpg   engine failure pictures-img_20140518_133927.jpg   engine failure pictures-img_20140518_133951.jpg
Old May 20, 2014 | 07:58 AM
  #22
Alloy Craft's Avatar
Former Sponsor
Yea, that is definitely mild detonation, causing the rings to shatter. Over time the ring pieces worked their way past the piston lands into the cylinder. the worst thing about this is that if you are turbo the ring pieces then crash into your turbine wheel and pretty much destroy it as well.
I has the exact same failure when my wastegate line popped off. It only detonated for less than 2 seconds and the damage was done.
Soviet
Jul 14, 2017 04:28 PM
Cyrax
Sep 10, 2013 07:02 AM
glennnr
Dec 2, 2011 03:03 PM
jwa4378
Apr 7, 2009 05:29 AM
SoCalIsMyLife
Aug 7, 2008 04:42 PM
