F20C Crankshaft Key
Old 09-01-2013, 01:49 PM
Renze's Avatar
Default F20C Crankshaft Key
Hey guys, I need some advice quick please...
Crankshaft key install, follow the Helms manual as it states?
Old 09-01-2013, 04:33 PM
jzz30's Avatar
Wrong key maybe? It shouldn't stick past the crank
Old 09-02-2013, 08:44 AM
S2K-F8's Avatar
I just put mine back together and had the same problem.
I just put the key in as far as I could, put the crank pulley over it, then slowly tightened the crank pulley down. This pushed the key into place, no issues.
Scott-
Old 09-02-2013, 02:17 PM
Spoolin's Avatar
I'm willing to bet that once you torque the pulley down, it'll push the key the rest of the way in and jam it up on the chamfers to hold the other sprockets much tighter. It's probably the way it's designed to work. Did you try lightly tapping it in further before putting the pulley on just to see what happens?
Old 09-03-2013, 05:53 PM
Banned
wadzii's Avatar
Thats how they are supposed to be
Old 09-04-2013, 06:26 PM
cuci591's Avatar
x2 just about every car I have ever worked on goes on that way.
Old 09-14-2013, 12:34 PM
1SlowSi's Avatar
Looks backwards. Mine had the tapered end towards the crank end. That was from Honda. Think about it, you want the non tapered in where it's supposed to hold the gears and pulley, not the tapered end. Yours is wrong trust me.
Old 09-14-2013, 01:03 PM
1SlowSi's Avatar
After looking at the helms, it shows the tapered end inwards like you have it. Weird cause mine definitely came out tapered end out lol. Mine is a 2008 motor and this is the 2000-2005 helms not that it should matter.
F1TwoThousand
03-18-2021 10:17 AM
s2klariat
03-15-2014 08:44 PM
speedjunky01
05-15-2013 03:36 AM
timg
11-23-2006 06:05 AM
C6400hp
05-25-2005 07:40 PM
Quick Reply: F20C Crankshaft Key
