Greddy Turbo Install
Yea, be sure to let the fuel pump prime before firing it up. It takes a good 3-4 seconds before its done primeing.
ALso the smoke is fine, just burnoff from the coating. Congrats on the install!
Thanks! I'll try letting it prime before hitting the start button. Where can T into for the BOV? Which tube is it on the Intake Manifold? You guys have been a lot of help thanks again.
EDIT: I used the FPR line. The BOV sounds GREAT now.
After 2 weeks I'm finally done with everything. The gauges are in and everything is hooked up. If anyone else is going to use the SOS pod pillar you be sure to remove the stock one first. I tried to fit it over the stock one and It doesn't work well at all. I think my fuel level senor is messed up. I drove around for awhile today and the gas stayed at the same level.. crap. Going for a ride now to see how much gas I can burn through.
Looks like my fuel leveler is good. Drove around for an hour and the level went down. Then I filled it up and its registered as full. Thank you to everyone and to Kix for providing this great thread. It came in handy sooo many times.
My gas mileage is much better since it was tuned, just slightly worse than pre-turbo mileage. I used to get about 21/26 and now I get about 20/25, but I also have 4.56 gears droning away killing my mileage as well. Without that my mileage would be awesome for how much whp I have.
