Greddy Turbo Questions thread....
Old May 17, 2008 | 09:32 PM
  #651
Chris_Lum's Avatar
Originally Posted by SOHCmyDOHC,May 16 2008, 10:36 AM
I'm gonna fab one up. Do I have to worry about the oil feed/return line?
Can't I just clock the cold side snail? Looks like there is a snap ring I can loosen and clock it?
Yes to clock the compressor side you just need to take off the snap ring and reposition it.
Old May 17, 2008 | 09:36 PM
  #652
SOHCmyDOHC's Avatar
Thanks chris. What do you suggest on the wastegate tab since the other holes aren't threaded?
Old May 18, 2008 | 08:55 AM
  #653
KnowledgeIsPower's Avatar
mr aqua i have the same problem with the tru boost. boost with come on then let off then come on etc.... its deff a tru boost issue though becuase if you run it on OFF and just run off the WG it holds
Old May 18, 2008 | 09:33 AM
  #654
SgtB's Avatar
EDIT: Forget all that.
My car does exactly as Mr. Aquas. It really is perplexing why it acts like that. I wonder if the WG is just too fast. It seems like when I punch it, it cuts down on the fluctuation.
What does everyones TB say at startup? Mine says UO4. Maybe there are different versions of the firmware.
Old May 18, 2008 | 09:40 AM
  #655
JoeyBalls's Avatar
I have a manual Boost controller, the way it is set, it Spikes at 10psi, then sometimes stays around 9, or sometimes 8, or sometimes just under 10, very frustrating.
Old May 18, 2008 | 09:58 AM
  #656
SgtB's Avatar
The AEM forum is saying that the Spr setting is to high, and to keep going lower until it goes away. All the Spr setting does is tell the TB when to start cycling the solenoid.
AEM Forum: "The number you input for spring pressure or wastegate crack pressure is when the wastegate BEGINS to open. You typically want to set up your duty cycle for the desired boost level first while the spring pressure is at 1psi. After you have your duty cycle dialed in, raise the spring pressure 1psi at a time until you get boost spike, then back it down to the previous number. Hope this helps."
Old May 18, 2008 | 10:42 AM
  #657
S2Kart's Avatar
I set my TruBoost according to the AEM forum like you are showing SgtB. I ended up with spr 5 and 10% duty to get 9.7psi when its cold out and 9.1psi in warmer weather. Mine is incredibly solid and repeatable, I mean within .2psi . I have a Berk HFC and dual 2.5" Dynomax Ultraflow mufflers, but the rest is "stock".
My TB shows "U04" then switches to "A10" (program A, 10%) on startup.
Old May 18, 2008 | 10:49 AM
  #658
SgtB's Avatar
Thanks for the tip. I'm going set mine back up in a few.
Unrelated: We need a build logs section like team-integra. It's so hard to compare setups here.
Old May 19, 2008 | 08:49 PM
  #659
TelosHedge's Avatar
install complete today! after a whole day's worth of driving and a couple of false alarms, i have found so far only one problem...
one of the injectors o rings has broken. you know the 2 o rings on the bottom of the injectors (black ones) - yea the TOP one of one of those is broken it seems. is that why there are 2, just in case? i guess i should replace it... does anybody know the sizes of these o rings?
Old May 19, 2008 | 09:27 PM
  #660
NFRs2000NYC's Avatar
Sorry to hear that, hopefully you can get a replacement O-ring.
For others, so you don't have this problem, use vaseline to lightly grease the O rings during install.
