Inline Pro 5965B turbo build
Old Sep 6, 2009 | 11:47 AM
  #31
TRBOKEV's Avatar
Originally Posted by Envied,Sep 6 2009, 10:50 AM
I am having quite a bit of trouble getting the manifold+turbo onto the block. Is there some sort of secret of installing the inline hot side?? It is almost there but just wont go. I have the 59/65 with E cover. How did you guys install your turbo, before or after the manifold was mounted?
I'm pretty sure it's after and I was told it's much easier to take the motor mount off then snstall the turbo and then put the mount back on. I still have to do this though..
Old Sep 6, 2009 | 11:52 AM
  #32
Envied's Avatar
How do you support the motor then??
Old Sep 6, 2009 | 11:55 AM
  #33
TRBOKEV's Avatar
A Jack with a board on top under the pan should work just fine.
Old Sep 6, 2009 | 11:56 AM
  #34
Envied's Avatar
So you have done this yourself before?
Old Sep 6, 2009 | 11:58 AM
  #35
AndyFloyd's Avatar
loosen that engine mount, put block of wood under oil pan, jack up slowly. Then realize how easy it is.
  #36
TRBOKEV's Avatar
Scott (DSDDCD) has... He's the one that told me to take the mount off etc...
Old Sep 6, 2009 | 11:59 AM
  #37
AndyFloyd's Avatar
I did and its fine, just jack it slowly with a 2x4 under the oil pan. Loosen the nut to the top of the motor mount and just jack up until you have the clearance you need.
Old Sep 6, 2009 | 12:00 PM
  #38
Envied's Avatar
Sorry I am just a lil frustrated at this point.
Old Sep 6, 2009 | 12:03 PM
  #39
TRBOKEV's Avatar
Understandable. I'll be frustrated in a few hours when I start working on the car again. LOL
pm him if u need more specific help but what I said is what he told me he did.
Old Sep 6, 2009 | 12:06 PM
  #40
Envied's Avatar
Thanks for the help guys. I started to notch the frame rail for clearance and found that there is a seam inside that is in the middle of the frame rail. So no I sorta have a hole until i can get something in there to shave that piece down. I am just stepping away for a lil while.
