Official forced induction chat thread
Old Jun 13, 2015 | 09:49 AM
  #1491
herecomesboost's Avatar
Originally Posted by ninetysixyenko
Originally Posted by liquid_helix136' timestamp='1434122707' post='23646117
So I've got a Hondata 4bar map sensor. How do I tell if it's for 00-05 or 06+?
I bought it for my Kpro AP1 back in the day but now i have an 07. I don't know if the 06+ one was needed for the Kpro setup or not.
Pretty sure 06+ only has one ear for 1 screw/bolt. 00-05 has 2 ears for 2 screws/bolts.
Yep.
Old Jul 30, 2015 | 03:08 AM
  #1492
MARK AUS S2K's Avatar
Originally Posted by spectacle
In case anybody cares, here's a link to my last pass at FL2k13. This was my second ever 10 sec pass to backup my first (which was the pass prior): [media]http://www.youtube.com/watch?v=ByBxcPH5Ijw&feature=youtu.be&t=35m35s[/media]
My pass is 35:34
And yes, I got f'n waxed. I will not be racing this year lol.
This is the BEST bloody video mate!!!
Old Jul 30, 2015 | 04:31 AM
  #1493
TerminatioN's Avatar
Originally Posted by MARK AUS S2K
My pass is 35:34
Still a good pass man. You can't expect to compete with a GTR unless you put major money into this car... probably close to enough to buy a GTR, lol...
Old Nov 10, 2015 | 09:30 AM
  #1494
omarisramo's Avatar
The bolts that connect the manifold to the turbo stay backing out. What studs do you guys use that prevent this? My bolts have backed out a handful of times, and this time sucks even more because i'm driving with only 1 stud in. I'm getting some studs tonight to put in.
Please, i'm sick of seeing no nut in the morning when I check my car. Any tips?
Old Nov 10, 2015 | 10:23 AM
  #1495
skinsfn36's Avatar
I think I've heard of people using Nord-Lock washers
Old Nov 10, 2015 | 12:08 PM
  #1496
cmn's Avatar
cmn
I had the same problem to begin with. I then went with Nordlock washers and copper nuts, and never had a single issue since.
Old Nov 11, 2015 | 09:21 AM
  #1497
Prokaw875's Avatar
What are most of you guys running for an oil pressure switch and line coming off the block? Can we post up some photos of what you are all running for your oiling needs off the block weather it be a common brass T fitting 1/8 NPT or something more elaborate like the P-Tuning oil/vac block or blocking it off and running it all off a remote oil filter housing like the canton unit. Just want to see what the cleanest and most effective is so I can decide what way I want to run my sensor and feed line.
Thanks!
Old Nov 11, 2015 | 06:44 PM
  #1498
NWDyno's Avatar
I'm running a golden eagle oil filter plate with Motec transducer coming off the 1/8 port.
Old Nov 12, 2015 | 01:29 AM
  #1499
Originally Posted by YELLOW JACKET
question to those running a sos stage 1 sc. i'm running the stage 1 kit from sos and it comes with a 4.8 pulley that provides 6psi. my question is has anyone tried running the next pulley size down(4.6)? this pulley is supposed to provide 7psi. I've looked at sos pulley and belt chart and it uses the same length belt. talk to sos about this and they said the system would not support that change in pulley size. my afr's now @ wot are in the 11's. i'm thinking I could run this pulley with no problem and gain alittle more hp off this setup with no issues. what do you think?
I think you need to get a 3.8 inch pulley, a new belt, and a re-tune and watch your smile grow!
Old Nov 12, 2015 | 01:44 PM
  #1500
JUSTINTHECOASTIE's Avatar
11's @WOT is what you want. You may be at the point to ditch the piggyback and move on to a standalone...
