Official forced induction chat thread
I've no authority to say how "proper" this is, but here is how my tuner has vtec setup (this is a new KW kit, 16psi, AEM Series 2)
OFF conditions
0.5 psi
3300 rpm
40% TPS
ON conditions
0.9 psi
3400 rpm
45% TPS
I have no complaints about part throttle operation with those settings. But I think you have a PD blower, right? So that could change things greatly. In some situations I will hear VTEC engage & disengage repeatedly when modulating throttle on a tight turn, but it doesn't hardly upset the car as I'm not making much boost in those situations.
To any AEM guru's, do ALL conditions or ANY conditions have to be met to engage/disengage VTEC?
OFF conditions
0.5 psi
3300 rpm
40% TPS
ON conditions
0.9 psi
3400 rpm
45% TPS
Hey guys how can I relocate my fusebox to this orientation? Does someone make a bracket for this already or do I just need to fab up a bracket myself? If there is something out there already I'll just buy that. I don't really feel like going through the motions of moving it into the fender, having to extend wires and all that crap.
I made one for a friend. I moved the steering box a little toward the back for a little space.
You can sort of see it bolted down here. It is not 100% solid as it just bolts to plastic.
OFF conditions
0.5 psi
3300 rpm
40% TPS
ON conditions
0.9 psi
3400 rpm
45% TPS
OFF conditions
0.5 psi
3300 rpm
40% TPS
ON conditions
0.9 psi
3400 rpm
45% TPS
question to those running a sos stage 1 sc. i'm running the stage 1 kit from sos and it comes with a 4.8 pulley that provides 6psi. my question is has anyone tried running the next pulley size down(4.6)? this pulley is supposed to provide 7psi. I've looked at sos pulley and belt chart and it uses the same length belt. talk to sos about this and they said the system would not support that change in pulley size. my afr's now @ wot are in the 11's. i'm thinking I could run this pulley with no problem and gain alittle more hp off this setup with no issues. what do you think?
