Official forced induction chat thread
Originally Posted by Habitforming' timestamp='1421272586' post='23468314
This is a question mostly focused on the supercharged guys, though in terms of longevity I'd love to hear from anyone with experience.
I'm taking a good hard look at going to a lightweight LiFePO4 battery, as my old lead acid is on its last legs anyway. The Shorai and Battery Tender are the only ones I've come across, but with almost no mention of the Battery Tender one. Does anyone that is supercharged have experience with either of these batteries? Do they have the oompf to get the engine fired up reliably?
My car isn't daily driven, and while I'm not wild about having to keep a battery tender hooked up, the $100 premium and 24lb weight savings are probably worth that sacrifice, so long as it will be reliable. I'd also like to know I can trust it for more than 2 years, but I don't think either has been on the market long enough to have any data to that regard.
I've been running on a LifePO4 battery for just over a year now. Was using a Ballistic battery but switched to a Stinger battery. Ballistic stop making the charger needed to balance the cells and I had a hard time finding one so I switched to a battery that doesn't require balancing.
https://www.s2ki.com/...relocation-diy/
Deka makes a lot of batteries for other companies. I know Braille batteries are made by deka. If you get the stinger like I have and plan on storing the car, get the ctek battery charger for lithium batteries. Mine is hooked up to one now since I don't drive the S much. It simply hooks up to the positive and negative terminals and you're done. From there it goes through a 8-9 cycle process from checking battery condition to maintaining its voltage.
Dustin, i think your car in its current state should beat that ws6 still.
If you dont want to switch a lot of stuff, just try getting it tuned on e85.
Andy made 30whp more on a comptech n1000 with a 3.2" pulley just by switching to e85. Nothing else changed except for a tune.
As for an e85 switch, I'm currently at 79% duty cycle and Im not certain I have enough room left for it.
I bought a supercharger kit that does not have an aftercooler, however, it does have an intercooler. I don't know if those are the same, I guess they are. But does someone know if that'll be ok for my AP1?
The kit is Comptech stage 1 (Novi 1000). I've heard that stage 1 Comptechs do not require tuning and can be run on stock ECU, stock fuel pump and injectors. CMIIW
Another added question: Would valve retainers and springs be upgraded in order to avoid floating from running stage 1 CT S/C?
Thanks
Thanks
Originally Posted by LordSovereign
I bought a supercharger kit that does not have an aftercooler, however, it does have an intercooler. I don't know if those are the same, I guess they are. But does someone know if that'll be ok for my AP1? The kit is Comptech stage 1 (Novi 1000). I've heard that stage 1 Comptechs do not require tuning and can be run on stock ECU, stock fuel pump and injectors. CMIIW Another added question: Would valve retainers and springs be upgraded in order to avoid floating from running stage 1 CT S/C? Thanks
If you run the basic pulley for ap1 (6psi ) and no other mods like tp,header,exhaust you should be ok with the RRFPR,fuel pump and ESM. Although it is not a great way to fully optimise and and enjoy the SC.
The retainers are another subject not related to the SC. But if you have an ap1 and don't know it's full history you should consider upgrading to the ap2's
Will adding a sc make my exhaust quieter? I believe I've read before that a turbo would but I imagine that's due to using exhaust to spool the turbo. Just curious and hoping the sc may quiet down the car a little.
Yes, you will not even be able to hear the exhaust after you install a SC...crickets baby!
Thanks
Thanks
