overboosting problem
Originally Posted by YuriArts,Feb 4 2008, 03:39 AM
that's why i'm getting a bigger wastegate. I hope the TIAL 44 will do the job.
Anyone running a TIAL 44 on an InlinePro manifold? What do I have to change, maybe make the hole bigger?
I'm assuming the 44mm is also taller, if thats the case, you might need to bend your AC lines our of the way as they are VERY close to the 38mm wastegate that is already on your system.
Originally Posted by BoostedK,Feb 4 2008, 09:49 AM
What if i go with a .62 ar instead of .82 ar will this be alright with the pfab manifold and the 38mm wastegate? please let me know thanks..
Also,
I spoke with pfab today and they said that their flow on their log manifold is pretty wastegate dependant and it should have very minimal problems with boost creep, and if anything the compressor housing can be switched to .63 ar until the car is tuned for higher boost.
Anyone believe this is agreeable?
Thanks
Also,
Thanks
Originally Posted by Spec_Ops2087,Feb 4 2008, 05:15 PM
optimally, you should change the hole.
The airco lines will be a problem I guess, maybe have to relocate it.
Can anyone else running IP manifold and a TIAL 44 charm in please?
Well atleast I have a shopping list:
TIAL 44 Wastegate Silver
TIAL 38mm to 44mm WG converter
TiAL V-Band Clamps
TiAL Racing Valve Stem
Large green + small yellow springs (1 bar)
cjb80
15
Jun 18, 2004 11:20 AM
