OVERHEATING in the desert
Old Jul 30, 2009 | 01:37 PM
  #121
juntuned's Avatar
Originally Posted by chairmnofthboard,Jul 30 2009, 12:19 PM
Looks like they're trying to blame Juntuned for it.
hey do you know of any way to actually test the strength of a new pulley, or existing aftermarket pulleys for that matter? Some sort of a stress test to see the tolerance of the metal before cracking begins. does such a test exist?
Old Jul 30, 2009 | 01:44 PM
  #122
Boofster's Avatar
Who sells the Toda pulleys? Can you buy them separately?
Old Jul 30, 2009 | 02:39 PM
  #123
azride1983's Avatar
can this pulley be use to replace the oem? are this more durable than oem? and will the reflash change ...
cut and paste...
http://www.gotuning.com/product_info.php?f...roducts_id=1198
Old Jul 30, 2009 | 03:46 PM
  #124
S2oooNvegas's Avatar
919.00 !!!!!!! jeezus christ. In yen its only 620....what a ripoff.
Old Jul 30, 2009 | 03:54 PM
  #125
azride1983's Avatar
yea its very pricey..but you think it can work with the KW kit without any tuning? will this hold up and not crack?
  #126
R1_Pilot's Avatar
I spent some time looking at my pulley under a microscope today. I showed it to a few guys as well for input.
Its very hard for my to say why my pulley started to fail, but I "think" I know how the crack started. I want to say its starting to fail from what I think is the pulley bending or sort of folding back and forth. You can say wobbling, I guess.
This could have happened due to three reasons; again, in my mind:
1. Me not properly adjusting the bolts.
2. the bolts loosing torque and the pulley becoming loose.
3. overtightening when installing (me again) and again the bolts stretched and let go over time.
Even though I never make mistakes , I am leaning towards #3. I used loctite blue on them ... so I probably overtightened them and caused the problem. They were not loose when I removed them.
I ordered 2 stock pulleys, because I think the stock pulley is more than enough once correctly installed and its stupidly cheap. That stamped steel pulley is hard, if you are going to change anything I would look more towards the bolts ... even though that might be opening a can of worms.
I do have a torque wrench that would have allowed me to properly torque it to 120 inch-lbs, but I failed to use it due to the fact that I did not have a way to hold the pulley the second time I had to remove my clutch.
I hardly doubt at this time that my pulley starting to fail is related to anything KW. And again theres is no one here that has a "virgin" KW kit and a pulley failure.
Joaquin
PS. I left the pictures of the pulley under the mic at work, but if you guys are interested I will post them tomorrow.
Old Jul 30, 2009 | 03:56 PM
  #127
R1_Pilot's Avatar
Originally Posted by archtop,Jul 29 2009, 09:47 PM
Can you get it X-ray'd ,like they do when they look for fractures in metal?
arch,
I cant ... but I am flying out to Michigan next week. I can bring it with me through the x-ray machine ..l lets see how far I go after that.
J
Old Jul 30, 2009 | 04:06 PM
  #128
archtop's Avatar
[QUOTE=R1_Pilot,Jul 31 2009, 03:56 AM] arch,
Old Jul 30, 2009 | 04:23 PM
  #129
Slows2k's Avatar
Honda has a pulley holding tool for the Civic, I'll have to check to see if it will work on a S2k.
Old Jul 30, 2009 | 04:32 PM
  #130
S2Kart's Avatar
How tight is the drive belt against the pulley in terms of ft. lbs of torque used to tighten the belt?
