Post your Catch Can Setups
Old May 11, 2011 | 05:14 PM
  #71
spdracerut's Avatar
Originally Posted by Torque Obsessed
Originally Posted by spdracerut' timestamp='1305146880' post='20564950
Another new setup dual can setup:
http://www.motoiq.co...il-control.aspx
Interesting. Any ideas where we can buy these?
There's a link at the end of the article.
Old May 11, 2011 | 07:30 PM
  #72
o'malley_808's Avatar
Old May 12, 2011 | 10:23 AM
  #73
bois2k's Avatar
Here is my set up
Size:  45.2 KBName:  s2kproject052.jpg
Old May 12, 2011 | 10:30 AM
  #74
bois2k's Avatar
Originally Posted by Deception' timestamp='1305148051' post='20565023
^^ Nice.. I just bought a Saikou Michi ORB 3 breather tank with 2 1/2" inlets & a 1.25" breather filter,
didn't know he made an s2k specific one, without the breather filter though its pretty useless for boosted apps.
Why do you say that? The only thing different on a boosted setup would be to run the one hose to the intake tube before the turbo/blower instead of in front of the throttle body. What do you need a breather for?
think he means vented to atmosphere
Old May 13, 2011 | 01:18 AM
  #75
Rob@ReidyRacing's Avatar
So these all vent off the valve cover. Is it possible to vent off the block too aswell as the valve cover. As far as B series applications go, this aids the turbo oil drain by relieving pressure in the system...
Old May 13, 2011 | 02:14 AM
  #76
H.A.R.T B18C1EG6's Avatar
Old May 14, 2011 | 06:11 PM
  #77
Deception's Avatar
Here is my Saikou Michi setup.. running the hoses from the stock ports on the VC (PCV is drilled out)
Old May 15, 2011 | 08:47 AM
  #78
siik_ap2's Avatar
did you do anything with the pcv???? ^^^
Old May 15, 2011 | 09:27 AM
  #79
Deception's Avatar
Yep I drilled the pcv valve out, so its just like a normal hose barb now. The stock valve is made for smaller hose though so I will need to get a 1/2" barb eventually.
Old Jun 1, 2011 | 10:03 AM
  #80
Boofster's Avatar
WOW...you do not need to drill out your PCV!
All you need is a $7 14mm x 1.5 thread fitting from SummitRacing or w/e to -8 AN (or -10)
http://www.summitracing.com/parts/MRG-A148M/
